Larger fuel pump
joebig
sc
Im needing to order a larger pump for my supercharged setup. tuner recommended a 400lph i had ordered a Walbro TU282HP-2 late last night but just read that it is tuned down.. is the dw400 a good solution?
86GT351
Sunny South Florida
Should be fine.
joebig
sc
does the hat need to be modified to fit the dw400 or just pops in? (other than the wires)
Laga
Chicago
I have the Walbro 400lph in my 05 with Edelbrock SC, 11 pounds of boost and E85. Never had a problem with fuel delivery in the past 7 years. It does have a BAP.
DieHarder
joebig
sc
you did the complete hat or installed just the pump in your stock hat? how do you like the SC? thats the one I got but still tuning
Laga
Chicago
I first replaced pump, then had some problems. The Walbro is not same size as stock so a little fabrication to make work. Replaced with complete hat and unit. Also, if you ever replace the passenger side fuel level sensor. This must be replaced with a Motorcraft unit or fuel level gauge will not be accurate.
I love the E-Force. Instant torque on demand. I had Lito change the shift points slightly on the 5r55s so it doesn’t do a 3rd to 1st downshift on track day. That just spins tires.
