NoviBlownGT
Boosted Crew
Car made 23psi at 7100rpms today. Be nice to rev it a little higher but I'm leaving those decisions to Lito. Poor little paxton is getting a workout.
Also thinking about ditching my bmr adjustable rear sway bar setup for an arb...
Well I pulled the methanol system and welded the holes in the intake pipe. Believe I had a small leak in boost at one of the ports. Never really used the system anyways. I'll be doing a air/water system this winter.
You'll love that FB 4r70w! I did my swap last summer, it wasn't too bad, they know what parts you need to make it pretty much a bolt in installation. The only issue I had was the shifter bracket they sent me had the mount welded on backwards, I ended up cutting it off and re-welding it the right way, no biggie. IIRC I re-used my OEM cross member, there was a bracket to use it with the 4r70 mount, I started with a 5r55s though so it might be different than yours. I didn't deal with the reverse lights on mine, just don't have em'. A tip I'll mention is to make 100% sure you put lots of RTV around the base of the Lokar dipstick tube they send you before you install it, otherwise it will leak! Don't ask how I know this...
Is it a lokar flexible dipstick? I ordered mine separately. Only ordered those few pieces from FB. I have the 6060 mount so had to order a 5sp crossmember. I'll probably do the reverse lights it doesn't seem to bad. Ordering the correct pigtails for the lights and the speed sensor.
Yes I ordered pretty much everything for my swap from FB and they sent the flexible Lokar dipstick tube for an AODE trans, which of course fits the 4r also. I'd be interested to see how you make out with your reverse lights and what parts you use, maybe I'll do mine later on if it isn't too painful. I was able to reuse the speed sensor from my 5r55s. The neutral safety switch was a little bit of a PITA on mine, but shouldn't be too bad with a stick shift car.
Went to Brenspeeds open house/dyno day over the weekend. Took home the trophy for Ford Highest Horsepower. 848rwhp was the number. Dyno was spiking a bit up there. Second pull showed 791rwhp. Either way I was pretty surprised.
Heading to bowling green this weekend to run true street.
