NoviBlownGT
Boosted Crew
I havent really posted much since I bought my old 3V back from Irishman. Just though I would share some updates with you guys.
First change was I went Blow through. Picked up and HPX-E maf and flange from pmas. Also fabbed up my own power pipe after checking out some of the power pipe builds on here. I think the upgrade was defiantly needed.
Then I had Lito work his magic again. Took the car from 620s into the 680s on brenspeeds dyno.
Had that done last summer and made one trip to the track. Pulled a couple 11.2/3s@130. I could tell the suspension wasnt liking the power or my 5500rpm clutch drops. So this winter I have completely redone the suspension.
QA1 DA Rear Shocks
BMR DA Rod end lcas
11-14 Style BMR UCA/Mount
BMR SB042 Rear Sway Bar
BMR Relo Brackets
Strange Single Adjustable Struts
Tubular Rad Support (No front sway bar)
13 Cobra Jet Springs
So hopefully that with some more seat time will really show was this car is capable of with the 6060 trans.
Also I'm finishing up an E85 fuel system. Jeremy from S&H has been great to work with. He has helped me along with recommendations and parts.
Twin DW300 Pumps in the GT500 Hat (PPRV Delete)
Kenne Bell Duel 17.5V BAP
Startlite -8AN Line from hat to rails
Fore Filter
Fore Rails
ID1000 Injectors
Just waiting on a few pieces to finish the line install.
Lito already has my startup tune sent. Cant wait to see what the differences are with E85. I've been testing my local stations so I can find the best and most consistent pumps. Everywhere has been between 85-87% except a Meijer stations. It was just over 70%.
I have some super lofty goals of trying to get this thing in the 9s with the 6sp. If I cant manage to do it this year then I'll have some thinking to do... Auto swap has been bouncing around in my head for a couple months now. if I do it will be the 6r80 if there is a controller for it, or it will be a 4l80.
But next up is the rear end. Thinking about just dropping a detroit locker with some strange axles and calling it good. Probably have a brace welded on also.
QA1 DA Rear Shocks
BMR DA Rod end lcas
BMR Relo Brackets
Fore Filter
Fore Rails
ID1000 Injectors
