Looking for tire fitment
Fredo23
Saint Paul MN
Got a set of VMS 17x10 wheels for rear. Wanted to know what size tires work best for fitment. Trying to get a set of street/strip tires
Fredo23
Saint Paul MN
2012 Mustang GT
1. MSD COIL PACKS AND PLUGS
2. MSD 2 Step Rev Limiter
3. Trans-brake
4. Cat back exhaust PYPES
5. 2018 Ported intake manifold
6. SCT X4 Tuner
7. 18in SVE Rims NITTO 555 tires
8. 17in VMS Wheels rears
12. BBK Long tube Headers
13. K&N Cold Air intake
14. Inter- Cooler
15. Stage3Comp Camshaft
16. Comp cam drive kit
17. Cat delete
18. 52lb Fuel injectors
20. Higher stall torque Convertor
21. SR Performance 8.8 Axles
23. 3.73 gears kit
24. Hi tect E85 Tune
Suspension Modifications
1.SR Performance lowering springs
2.SR Performance adjustable pan hard bar
3.SR performance Sway bar kit
4.SR Performance shocks & struts
I mean this the build list right here the numbers might be off but that because I deleted the stuff I don’t have yet
28"
MT - ET STREET S/S SIZE: P305/45R17
M&H
ROD-19275/50R1710.1988928.00Yes
26"
MT - ET STREET S/S SIZE: P275/40R17
07 Boss
Sin City
Best tires for a street/strip set up would be MT Street R or S/S. For the best DOT stamped tire for a strip/street set up go with Hoosier QTP's. With a decent sidewall height you can go as wide as 12" but if you are going with a lower profile tire I would stay within about an inch of the wheel width. But remember, none of these tires do well or do at all with any moisture on the ground. In fact they are quite dangerous to drive in the rain. If you need something that can handle rain I would look at the MT Street Comp, at least they have a wet weather rating.
MrBhp
What's the purpose of No.14 inter- Cooler?
