I bought a T56 Magnum trans and QuickTime SFI-certified bellhousing yesterday - the shop that's helping with my swap bought it for a 351w fox body and after getting the motor in the engine bay, realized it wouldn't fit because of a) headers and b) clutch cable, so I bought it from them. I'm currently looking for the absolute best price on a Dart SHP block (so far, $1735). Once the block is ordered, I will be ordering the rotating assembly.
Pre-build Thinkin':
When I have nothing else to occupy my mind, I mentally go over the affected sub-systems, and try to anticipate any issues that might crop up. Keeping the EPAS is a relatively late development, so I was thinkin' on it this weekend.
I was looking at the EPAS (in pictures on the net), and it's looking like it's going to be a TIGHT fit, even after grinding off offending appendages and bracing. I am "concerned".
We're going to try to find a wrecked 2011/12 and get the EPAS off of it for the purposes of test fitment. Then, before bolting the k-member to the frame, we're gonna bolt it to the engine (while it's on an engine stand) and do our trial/error fitting with the EPAS. This will make it easier to get the EPAS on/off the K-Member, and the oil pan on/off the motor while modifying stuff.
I already know we have to mod the EPAS to bolt up the the BMR K-member, but the real issue lies in whether the EAPS/K-member assembly will fit in the space allotted by the oil pan (between the oil pump and the sump area).
The oil pan is going to be a Moroso 20520 7-quart, and the K-member is going to be the BMR KM012 (351 swap into S197). BMR said they could probably assist in clearancing the EPAS for their K-member, but I'm going to be on my own regarding the oil pan.
Oil Pan:
EPAS (on OEM K-member):
I have a Fox body available with a BMR K-member and a 351w with the same oil pan, so I can at least measure how much room the oil pan allows, but I won't know how much room is actually available until I can attach the K-member to the block with the oil pan installed, and then try to fit the EPAS. I'm hoping that (if necessary), we can ground off part of the the front of the EPAS. It looks like there's a tab running the length of the control unit that doesn't appear to do anything (in terms of bolting to it or supporting other parts).
If I can't keep the EPAS (which would be a huge bummer at this point), I'm going to have to spend an additional $700 on hydraulic power steering parts.
