jsimmonstx
Oil pressure isn't needed for car to run without codes (I've already replaced it with aftermarket gauge).
Can't use the stock alternator, but adapting a 94/later shouldn't be an issue.
CHT sensor probably isn't needed either - a tuner can be used to turn off codes (from what I understand), but I might be able to retain the CHT sensor by drilling/tapping the a head and simply plugging it in. If any of that plan goes awry, I'll just rip out the dash and replace the cluster with all aftermarket stuff.
