I'm no expert, but with that kind of power and 4.10's shouldn't you be running a 28 tall tire.
I thought 50/15 were 26 tall and 60/15 were 28 tall.
WOT box
17psi
So far my best 60' is 1.9 on ET Streets (325-50-15). I have moderate power - 460whp.
I do a burnout, hold it at 60mph for about 6-7 seconds, turn off the line lock and roll forward, when it hear the tires squeel and push in the clutch and stage. This seems to work well because the tires get super sticky.
I hit the 2 step (3k to 4.5k) on the 2nd yellow, drop the clutch on the last yellow and keep it floored.
This clearly isn't working for me.
I just read in another thread to let up on the gas as your coming out of the hole and/or slip the clutch. This makes a lot of sense, but I don't think I could get my feet to do that...
How do you launch? Slip the clutch, drop it, wot, let up on the gas, etc..
+1 to what lightblade said. I haven't tried to launch a centri or turbo so I don't know how they work for launching but with my e-force it's finding the right balance of rpms to put the 2-step at and how much to slip the clutch. 3500 rpms is the sweet spot for my car now but at that I'm leaving on approx 10 psi of boost.
I can nearly dump it now but I paid the price for that last night busting something in the rear diff. Getting the car towed to my friend's shop today to figure out what we're going to do. Probably going to a locker now.
^^yep, people often say bias ply for a stick and drag radial for an auto... but the meaning behind it is that the bias ply tires can absorb the shock of a hard launch better than the drag radials can. You have to be smooth on a radial because if you spin it, it'll be next to impossible to recover. (run is wasted)
You CAN use DRs on a stick car, but you need to be smooth on the clutch and throttle.
For whats its worth I had a Mickey Thompson rep tell me their drag radials are pretty much worthless with a manual trans. Not saying they can't work but they would try and steer you in another direction like the bias et streets, at least they did me.
