- Shocks - strange single adjustable
- Rear springs - cobra jet (m-5300-q)
- Struts - strange single adjustable
- Front springs - cobra jet (m-5300-q)
- Lower control arms - metco
- Relocation brackets - BMR
- Upper control arm - metco (with metco UCA mount)
- posi/diff - eaton truetrac
- Pan hard bar - competition engineering adjustable
- Pan hard bar support brace - competition engineering
- Gear size - frpp 4.10
- Brand/ tire size - M/T ET street (bias) 26X10.50-15
- Clutch or which converter at what stall? - OEM clutch
- Anti roll bar or which rear sway bar - OEM sway bar (no arb)
- 302 rwhp
- 3490 lbs race weight
pinion angle set to -2 deg
LCA set to middle hole on BMR relocation brackets
UCA set to uppermost hole on UCA mount
12.095 @ 111.08, 1.576 60' (new pb all around)!!
track rental at MIR 22NOV14. DA was -1895 ft for first run, and warmed up for subsequent runs
weight 3490 with driver/helmet, 1/4 tank of gas
pass seat and rear seat bottom/backs removed
ps delete belt
front strut full loose
rear shock +7 clicks from full soft
15psi cold in rear tire
6500 rpm launch off limiter
