Max Motorsports Rollbar
jsimmonstx
Comal County, TX
I got a MM 4-point rollbar with the welded harness bar and optional diagonal bar. It took us all day yesterday, but we managed to get the rollbar situated. I had watched the Late Model Restoration youtube video, so I had a kind of idea of what to expect. If you're not going to be putting the interior pieces back in your car, you're pretty much golden, and it should only take you a few hours to install the bar.
Otherwise, expect to spend a full day (and pushing into the early evening) getting things situated. Here are some tips and info:
0) You need a helper. This is NOT a one-person job.
1) Your most important tool is "the big hammer". We needed a sledge hammer to coerce the front rollbar feet into an acceptable position. The only hole that lined up with no issue was the outer-most one on the vertical part of the foot.
2) You're going to need the rear tires and rear wheel well liners off the car so you can drill holes for the rear support plate.
3) The top of the rollbar may be in constant contact with the headliner. Mine is.
4) For added structural rigidity, you can optionally well on a tab that bolts the bar to the B-Pillar, but since the rollbar doesn't come that way (and it doesn't appear as if MM offers that as an option, fabrication of the tab is required on your part.
5) If you have a bad case of gas, warning your helper ahead of time is not only fair, butt it's the decent and humane thing to do.
Now that we've done the fittings/cutting, we're ready to send the bar parts off for power-coating on Monday, and should be able to perform the final install by Tuesday/Wednesday. Pictures will be forthcoming at that point.
mitch
HPDE Instructor
Ft. Lauderdale
Congrats, and good choice.
Looking forward to the pics. What color you going with?
One more thing, did your harness bar come with the little "loops" to keep the belts in the correct spot on the bar? Mine did not, so, I had a buddy fab and weld them on.
This is the best pic I could find of what I'm talking about. If you dont have those little bars, the belts have a tendency to move on the bar.
jsimmonstx
Comal County, TX
No, it doesn't have those. :(
It's gonna be white.
DTL
SoCal
I wish I would have put harness loops on my cross bar before installing my MM cage. That, and I would lop off the tacked-on nuts on the kicker bar plates. Half of mine weren't welded on straight and the compound curves back there make it nearly impossible to line up the bolts properly. Ditch them and use nylocks instead.
jsimmonstx
Comal County, TX
Too late - the rear legs have already been powder coated. Here's hoping for straight welds. :/
MustASH
Canada, Qc
Just installed my 4 pts MM rollbar :
MustASH
Canada, Qc
I welded some tack on the main hoop bracket, welded rear brackets to the main hoop and fill welded the rear brackets holes so it doesn't look like a "3 pieces bolt-on" rollbar anymore.
Painted with VHT Roll bar and chassis, satin black.
I'll drill the plastic trims and reinstall seats and I'm done !
MustASH
Canada, Qc
Ah, a Vert with a roll bar looks fantastic!!! Looks great man!!!
Thanks mitch !
Yeah it looks badass enought. Can't wait to see chassis rigidity improvement on the track. I ride on the road yesterday and I found it feels really stiff compared to my previous light bar. :peace:
Boone
Automotive Enthusiast
High Point, NC
A rollbar in a vert is like cheating. I can't count how many times I hit my head during my coupe installation. A vert could have eliminated the blood soaked towel that I kept wiping the back of my head with?
The only issue I had was on the rear legs. They are a PITA, and I believe one leg moved a little when I set the bar on the floor after the fitment and before the weld process.
MustASH
Canada, Qc
Trust me, I did hit my head too even it's a vert ! I think it's a mandatory step of the install... :roflsquared:
07 Boss
Sin City
Ohhh ohhh... I got an issue :
Put that thing in the front seat. I have had a few occasions where I've had to put the car seat up front. I would never have the kid back there with a roll bar. Chances are he (or she) will bang there head on that bar because of it's proximity.
MustASH
Canada, Qc
I did not install the seat, I was just trying to see if it fit after the rollbar installation, and it's doesn't.
I don't think I can put the seat in front with the legislation of Québec, Canada. But I'll verify for sure...
I wanted to surprise my daughter by going at pick her at daycare with the Mustang... She loves it. :(
Scott_0
OxFORD, Pa
not trying to judge here, but I wouldn't put a kid back there with a steel bar that could kill them in something as minor as a 5mph collision, wouldn't take much of hit to kill or seriously injure a small child, once a bar goes in, the little ones stay out
sent from my S6 using tapatalk
