Noclutch
What a bunch of .....The car is mild modded (bolts on), no the cams are bolt ons as would be heads, no SC is not a bolt on it is a power adder, His tires suck because of the track prep and his wheel hop is costing him. The car is cranking out some good hp and the driver is doing quite a good job on his runs. He has a lot left to do as far as bolt ons. 4 major engine changes : Intake, Tune, Exhaust, Valvetrain. Lighter mods CMDP, UDP, Electric Water Pump. Major changes in drivetrain: Gears, Driveshaft, Torque Converter/clutch, Flywheel. Suspension: Springs, Shocks, Control Arms. Then we have Tires: DR's or Slicks.
I define BOLT-ON as taking off the stock part and replacing it with a modded or after market part. (no, stroker kit is not a bolt on)
He has a long way to go and the more he does the closer he will get to the low 12's if not touch the high 11s. The more you do and the quicker you go the harder it is to show the gains.
Tires are good for .4 if he ran with streets and got a 2.x 60 he would be in the high 12s. Still impressive with the mods he has. I make this comparison as I run on streets and watched time and again guys making only the tire switch making those kind of gains.
Good Job OP! I hope to see you post more.
BTW, I hate you.
BTW, I hate you.
