Misc parts, including a GT500 tank and Moroso Catch Can
1950StangJump$
In my engine swap and conversion from a Kenne Bell to a VMP blower, I am ending up with some extra parts to sell all prices are plus shipping and Pay Pal unless we work something else out:
GT500 degas tank with drain. Paid extra to get the red cap. $200
Moroso Catch can. Worked great. Hangs on your left tower and the hose currently on it will go straight to your left PVC. The long hose will depend on your setup. $85
Prosport oil filter adaptor and Aeroforce oil temp sensor. Perfect setup if you have an Aeroforce and want to add oil temp to the things it can display. The adaptor has 4 total ports if you want to add any other gauges (like oil pressure). Note that I have two ports plugged. You'll need to either use both the others or plug one if only interested in the temp. $25 for adaptor and temp sensor.
1950StangJump$
Also have:
VVT Sensors, camshaft sensors, and the crank sensor. All off a car with 24k miles. $20 each
Also, stock cams ($50), stock belt tensioner ($20), oil cap ($5), brand new water pump fitting to hose ($5), stock water pump with 24k miles ($25), and stock PS pulley ($10).
Also have the bracket which will allow you to move your PS tank off the radiator shroud and onto the valve cover ($10). You'll still probably need to change your hoses to move the tank.
1950StangJump$
One more thing. I have a fuse box cover that has the Silver Horse billet cover on it. There is a little damage from the KB intake tube that sat on it.
The Silver Horse is $100 new. Will sell the whole thing there for $30.
Also have some idlers. $3 each
Shotokan1509
CT
Dang I just bought the catch can new. The degas tank does that fit between rad tank & power steering tank or does it require moving the power steering tank?
1950StangJump$
You would have to move the PS tank.
I have the bracket to do that for sale. I didn't list it, but I also have the different shaped hose (tank to pump) that's needed for that relocation
1950StangJump$
GT500 tank and PS bracket/hose are sold.
Update on stuff still available:
Silver Horse fuse box cover
Belt tensioner
Moroso Catch can
Richie
Indianapolis
What would you take for what you have left. Need them shipped to 46131. Franklin Indiana.
46addict
13726548
Lawrenceville, GA
Also have:
Do the cams include the phasers?
