Motor build advice
Weou09
Bham, Alabama
Waiting on Jeremy and Bobby to take my money for some bosch 1000s and Bobby's Fore fuel hat. PMed Steve to get a quote on boss rods, 13 gt500 oil pump and head changing kit.
Weou09
Bham, Alabama
Got a good bit done today. All the wiring is loose and out of the way. All but 2 of the bell housing bolts are out. Also worked on the interior and dropped the gas tank to get all the fuel out.
Weou09
Bham, Alabama
More done! Got the block ready to go to the machine shop tomorrow. Should start receiving parts as well. I did get the injectors today, thanks again Greg.
W3bb3r04
Slow 3v Member
Clinton, TN
Did you pull your ac compressor and lines and power steering pump and lines or did you leave them in the engine bay?
JoshK
Modder AKA Fuel
Nebraska
Leave them in the engine bay. no sense in unhook things you dont need to
W3bb3r04
Slow 3v Member
Clinton, TN
I'm planning on spraying the engine bay but ill see how in the way that stuff will be
Weou09
Bham, Alabama
What color?
Flat white or burnt orange. Can't decide.
Also while I have the heads at the machine shop, I am doing valve springs and seals. Should I replace anything else or is that all?
Edit: How much exhaust wrap will I need to do the complete hot side?
Weou09
Bham, Alabama
Scored the "last" set of Mahle flat top pistons from CNC-motorsports for $485, WHHHHHAAATTT!!!! Thanks Bruce for pointing me in their direction! Saved me lots of money! I have a total of 760 dollars in Manley H beams with ARP 2000 bolts and Mahle pistons! SO EXCITED!!!!
W3bb3r04
Slow 3v Member
Clinton, TN
That's a good deal! I have $480 in my rods and pistons haha
Weou09
Bham, Alabama
Thats a killer deal. I stayed up every night after I decided to build before it went south, and just couldn't bring my self to buy the boss rods. Considering I only paid about 120 dollars more for the H beams and ARP 2000 bolts, I think it was the right decision.
W3bb3r04
Slow 3v Member
Clinton, TN
Yeah that's definitely not a bad choice!
fordracer666
Where did you get the boss rods from ?
And would it be hard to pull the tranny the same time?
I'm getting ready to pull my motor soon !
W3bb3r04
Slow 3v Member
Clinton, TN
Have you decided on a valve spring yet? Are you locking out or getting something adjustable?
Im going with the Trick Flow Springs from Summit. They are $200 and Im probably just going to lock them out. Its cheaper and less of a headache.
I picked up the Rods for $162 from tousley along with a 2013 GT500 oil pump for $62. Id say it isnt bad to pull the trans at the same time. It just takes some finessing.
