My adventure with Fastlane Inc.
05mustang_TT_charged
Because Race Car!!
LSU Country
I am waiting for a couple tweaks to the tune to stop a CEL for some VCT code I am getting. Seems like the VCT has a sensor for everything it does and sees. The code is P0021 Cam A Over Timing, which I am not sure if it is because the were degreed in at 109* that it is showing over timing.
I dropped the car off to get a plug change and a new tune. They decided to strap the car down and check everything first. Well the figured I didn't need a plug change and the HT0's that were in the car were fine. Which saved me $350 because of the price of the plugs and labor to pull the supercharger off to change them. This was something they didn't have to do because I told them to change them. They figured the tune was off and not bad plugs as I thought. So they are some stand up guys in my book just because of that. They could of easily taken my money and never said anything about not needing the plugs but they took the high road and I am very appreciative of that.
They erased the tunes from the previous tuner and started with there own. The car was locked into Open Loop and added 2 more degrees of timing. So now the computer is commanding 17* of timing instead of 15*.
The car made a solid 600 rwhp and 530 rwtq after a couple pulls.
The car runs smoother and is easier to drive but did take a hit in gas milage. Since the car doesn't look at the o2 sensors anymore and just the Mass Air the gas milage went from 28.4 mpg on the way to Houston to 13.8 mpg on the way back home. I have been driving it around town and it is a steady 13-14 mpg weather it be on the interstate or driving around town. I am not worried about gas mileage so that doesn't bother me.
I changed out the Lightning Mass Air I had to another piece of 4" pipe for the intake and it made another 1 psi. On the last dyno it made 16 psi. and on the one at Fastlane it was making 17 psi. That goes to show how any inlet restriction on a twinscrew car hurts the power.
The car makes 490 rwtq at 2500 rpm and goes over 500 rwtq at 3600 rpm and at 7000 rpm the car is still making over 500 rwtq. It drives like a totally different car now and seems to be alot faster.
Sorry this post is so long but I thought I would get the info out there. I will also be bringing the car back after a couple fuel system upgrades for the race tune which should be on 20 - 24 psi. I love the new street tune so I can only imagine what a good race tune will be like.
Hawgman
THE fucking bad guy
Texas
You will get tired of driving it in open loop... trust me
cekim
Large Member
Earth
Well, if tuned correctly it isn't all that bad - its just a PITA for the tuner to get it right and it will mean some days the car runs smoother than others as there is no short term trim...
Kevin@PMP
Concord, NC
Commanding open loop full time can become a necessity for the best driveability with aftermarket cams which sometimes will cause the STFTs to go nuts at idle and kill driveability.
Because Race Car!!
LSU Country
Why would you need to pull the SC off to change plugs?
I have the custom sheetmetal intake from Adam and it is huge...I had to beat the firewall in to get it to fit.It covers the 2 rear plugs on the passanger side
I have been noticing that on really hot days it runs a little crappier than on cooler days, and it runs better early morning and late afternoon
I noticed that the new tune from Fastlane has been hands down better than the old one
Because Race Car!!
LSU Country
probably not some of the bolts are inside
MLC40
Naperville, IL
I was planning to buy this setup from Adam when I have a built SB installed. If you need to pull the blower off to change plugs I will take a pass as I an on my second set of hto's this year alone.
Ron, you have this setup don't you? Can you pull the plugs without pulling the blower?
ChevyKiller
Preferred Internet Drink
On my KB the 2 passenger side were a PIA - but it was possible to change them by simply taking off the intake. I don't see why you can't do that either. Invest in a small swivel head with an extender to reach those hard to get places...:idea:
Because Race Car!!
LSU Country
might try it with it on but there is no way I can get the rear one because I can't even see the coil pack. as far as I know this is the only sheetmetal rear intake for a KB Adam made, it is the one off jsawyers car
ChevyKiller
thanks, but it isn't a 3.4l...I am still on the porch when it comes to you guys...not running with the big dogs
In all honesty, a bigger blower on our cars only works better if you have more ci - otherwise, it's a wash HP wise...:idea:
I don't think anything bigger than a 2.6 is going to really do much more unless you are over 6 liters IMO.
The guys making the big GT500 numbers on the mammoth and whipple 3.4 kits are about the same.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
He's putting one on my car now... guess I'll see how much of a PITA it is.
Because Race Car!!
LSU Country
awesome, I couldn't be happier with all my dealings with him..I just wish I lived closer to Cali. of had someone around here that does work like him.
