Paps
That's what i'm waiting for! Try those injectors. May have same issue
I've found once you go into a car like we have the dealerships are going to have a very rough time with diagnosis.
How are your grounds?
I haven't checked all but the ones so far have been ok. Something is causing a strong vibration or rough idle. You can feel it in the driver seat at idle and the floorboard.
I checked/tightened the motor mounts and transmission mount but didn't change anything.
Any thoughts?
These issues started when I still had the Autolite Plugs in my car, so then my journey began trying to find/fix the issues.
I have new injectors on the way but after more reading into the camshaft sensors I ordered those too for tomorrow. I have a very hopeful feeling that these are my problem, if so I'll explain why afterwards.
Been listening and trying to narrow down this vibration, I think it's either my A/C Compressor or Harmonic Balancer Pulley. When at normal operating temp and idle you can feel the vibration pretty easily, but when I turn on the a/c each time it cycles my rpms drop and the idle is worse?
Anyone ever heard of compressor probs with rough idle or bad vibration?
Also make sure your compressor is not loose.
II think on my stock motor, my compressor bolts became loose and caused a whole lot of vibrations.
It is possible that the original plugs were going bad and you replaced them with bad plug/s.
Forced induction is hard on plugs. They should be changed every year at a minimum.
AC has it's own tables for idle and airflow. It's possible that the a/c portion of your tune needs a little attention or that it's magnifying your original issue.
Installed new HT0's, rough idle remains. Crankshaft pulley should be here this week hopefully![]()
Stock pulley? Who did you order from?
