KungFuHamster
damn. after seeing the previous post...and knowing that my car is about to roll over 1k miles, i may seriously look into one of these things.Very very cool, thank you for posting!
A must do mod for sure!
Jay
Jay
My black can is still on back order. Any idea when you might get some more in?
I ordered one about a week ago, and they told me it would ship out today as they were waiting on the hoses from Ford. I really hope it does because I want this thing in ASAP lol.
I just installed mine today. Install took maybe 30 seconds once I got the engine cover off - but you should probably mention that if you have a STB, that will need to come off in order to remove the engine cover - it won't slide under the STB. 4 13mm bolts and it comes right off. It's heavy!
I'll check back in a few hundred miles to see what all it's caught.
(yes, this is copied from TMS, but I figured I'd say it here too)
We don't have a plug and play kit for the KB cars, but you can get our base kit and plumb it yourself very easy.Hey Jay! I have a Kenne Bell on mine and the hose has been extended from where it usually goes back into the intake, can I send you a pic to see if I can have you fab something for my set up? thanks in advance!
Frank
\/ \/I just installed mine today. Install took maybe 30 seconds once I got the engine cover off - but you should probably mention that if you have a STB, that will need to come off in order to remove the engine cover - it won't slide under the STB. 4 13mm bolts and it comes right off. It's heavy!
/\ /\Actually, I just lifted up the corner of the engine cover and installed it. No removal necessary.
