Sep 2, 2011 #1 Cammed 05 Always happy Joined Apr 14, 2011 Posts 488 Reaction score 1 Location VB, Fl Is the tps resistor wire a necessity? And where is the best place to splice? Also would I be able to use a regular toggle/ flip switch for the arming switch? Thanks folks.
Sep 2, 2011 #2 s8v4o Senior Member Joined May 18, 2007 Posts 3,476 Reaction score 10 Yes it needs to read the TPS signal 6 inches from the sensor is easy to get to Yes you can use it
Sep 2, 2011 #3 Cammed 05 Always happy Joined Apr 14, 2011 Posts 488 Reaction score 1 Location VB, Fl Thanks for the quick reply man. I've got the white wire, just not the physical resistor wire needed or that's listed in the kits.
