SilentScope
Chemist by profession
So I'm in the middle of some "intake mods" and i installed 2 x 12" slim fans.
The stock Fan/shroud had what seems to be a coil/resistor sensor.
A metal device with a coil and resistor.
its the first attached picture.
1) What is this/what does it do.
2) Then, In the second picture will positioning it as such be sufficient? or can i just remove this device completely?
I assume its the heat sensor?
Can i get rid of it or should attaching it as seen in the picture be OK?
thanks a lot for your help
