1FastS197
its wrecked and we are wanting to hear it run... the theft light is on and will not turn off... looked for the inertia switch but apparently it doesn't have one... fuel pumps will not kick on, the maf has been pulled off but it should still crank and go into limp mode right? its an auto.... it had a aftermarket security system but is now removed and everything is pluged back up... does the PCM need to be reflashed? or is there some trick to get the it out of the theft lock? any help on this would be greatly appreciated...
