Need new timing componets
mrmonk7663
Humble, TX
Im building a new motor. The last one had some vct issues. I want to use all new parts. New vct housins, new phasers, new timing chain, and whatever bolts I need. Can someone point me to the right direction of where I can get this stuff at the cheapest price? Also, should I look into replacing the guides or not? Also I want new cam tensioners...the steel ones. Part numbers and where to buy would be awesome. thanks guys.
AndrewNagle
Mountains of NC
Either Tousley Ford or Silverstate Ford both sell at 10% over cost.
Also get the 2004 timing chain guide tensioners , these are metal not plastic like in the 05+ Part #'s F6AZ-6L266-DA Tensioner - RH (2 Valve Steel Bodied and F6AZ-6L266-CA Tensioner - LH (2 Valve Steel Bodied)
Good Luck
andrew
kenneth
Louisiana
I bought most of this from www.silverstatefordparts.com
(1) F1AZ-6B316-AA Key (Crankshaft Gear)
(1) XL3Z-6306-AA Gear - Crankshaft
(2) 5W7Z-6268-AA Chain - Timing
(1) 4R3Z-6B274-BA Chain Guide - LH
(1) 4R3Z-6M256-CC Chain Guide - RH
(1) 1L2Z-6L253-AA Tensioner Arm - LH
(1) 1L2Z-6L253-BA Tensioner Arm - RH
(1) F6AZ-6L266-DA Tensioner - RH (2 Valve Steel Bodied)
(1) F6AZ-6L266-CA Tensioner - LH (2 Valve Steel Bodied)
(2) 3R2Z-6A257-DA camshaft phaser kit (bolt included)
frarmar
Killer boots man!
Southern Illinois
I'm curious about the guides too. They don't seem like they are something that would wear out??? Are they a "while I'm in here" type thing?
kenneth
Louisiana
Yea, pretty much, my old ones still looked good with 60,000 miles, BUT since it was apart, cheap insurance.
mrmonk7663
Humble, TX
This is alot to ask but does anyone have part numbers for this stuff...
Guides
Cam Phasers left and right
Timing Chain
Phaser Bolts
VCT housing left and right
Tensioner part numbers are above.
Aside from these parts is there anything else i'm leaving out that I need? I have cams/springs/retainers and will be getting new followers aka lifters soon.
Thanks for all the help.
kenneth
Louisiana
All parts are listed above, not sure what you mean by VCT housing though.
