Need stock h-pipe measurements
o2sys
Does anyone have their 3v stock h-pipe on hand that could take some measurements for me?
Need the distance from the inner H and outer H:
Don't have a stocker on hand.
Thanks in advance!!!
Sent from my iPhone using Tapatalk Pro
gavin.biegler
i believe i have one in my garage i can take a look when i get off work today, if no one else helps you out sooner.
07 Boss
Sin City
Do you mean the pipe diameter? You have 2 horizontal and 4 vertical lines, where do you need the measurement? A little vague because there is no really in between as one sits inside the other. But the way I see it the distance between the two H's is 2.5" if your looking across. If your talking about the distance between the bottom of the small H and the middle of the big H it looks pretty darn close, can't be over a 1/2".
Phil1098
Central Illinois
I just measured mine and the inside distance between the pipes is 2 3/8" and the outside from edge of pipe to edge of other pipe is 7 3/8".
o2sys
Yes I was looking for the inside distance and the outside distance. Thank you
