Need trq specs quick
gtmiller1001
Houston
Hate to be that guy but need torque for intake manifold bolts and fuel rail bolts for 11 gt.
Not at house and can't view workshop manuals in iPhone
TIA
JoshK
Modder AKA Fuel
Nebraska
Intake
Stage 1. Tighten to 89 lb-in
Stage 2. Tighten additional 45 degrees
Fuel Rail
Stage 1. Hand Tighten
Stage 2. Tighten to 89 lb-in
Stage 3. Tighten additional 90 degrees
TexasBlownV8
Formerly TexasBlownV6
Central Texas
So, is the additional rotation new for the '11s?
89 INCH-pounds and then additional rotation is putting some stress on those small bolts; although, 45* more shouldn't be a problem. just 2 cents :)
05stroker
Never enough power guy!
Bullard Tx.
In layman's term 89 in lb = no harder then you would twist a woman's nipple.
I have never torqued an intake. I always "snug" it down then make another pass making a 1/4 turn. Just my .02.
gtmiller1001
Houston
Thanks to all who responded so quick! Unfortunately I had to wrap up an take off. Now that I look at the specs, I definitely FAR exceeded them :)
bullitt boy
NJ
89 inch = about 7.4 foot lbs? Thats like hand tight almost.Good to know.
All depends on the fastener size. It's best to always use a torque wrench. I deal with fasteners torqued in inch pounds all the time and can tell you it's more than it sounds like. 25 ft lbs. on an idler pulley feels like alot less than 35 inch pounds on a 10-32 fastener. FWIW I'd say 8 inch lbs on a #06 fastener feels about like 25 ft lbs on an idler pulley to me.
The only rule of thumb that is somewhat consistant is tight plus a little more will usually get you by. For some reason proper torque always feels tight no matter what the fastener size.
