new 5.0 going flat at full thottle
Ducky
if it was the torque management killing your rpm's wouldnt the traction control light flash at the sametime it acts up?? i know ANYTIME i get into and the tires break loose (w/ the tcs on or just halfway turned off and NOT all the way turned off) the tcs light flashed in the guage cluster. when the TCS is TOTALLY turned off, i get no flashing whatsoever.
I think the TM and TCS are independent of each other. My 06 V6 would throw a code on a cold morning if I got on it too soon that said "too much torque", but it would go into limp mode until I restarted. TCS would never activate though. I don't know if the 5.0 will still go into limp mode for it or just throttle back.
05yellowgt
Dayton, OH
Have you checked the A/F when it does this? I was just reading Beefcake's thread about 02 sensor extenders and causing issues. Happen to be running extenders?
STEVE_POE
coyote powered fr500s
Cincinnati
stock headers and air fuels are fine.
The ecu is not tunable at this time. nobody has anything for it strategy code yet. Since it's a ford racing item and very limited on sales sct and diablo have bigger fish to catch so I can't just go in and change something "sucks"
05yellowgt
Dayton, OH
Check with MattD on here. I think he has been tuning on his Coyote Crate engine he dropped in his 05-10.
Trbosvt
Simi Valley
This is the ford Racing kit right? i used the same kit and i tuned it with SCT!!! if you have a SCT programmer you can read the strategy and it should read M2A3_X01_CRATE_3. Don't let SCT tell you you can't tune it. it took me a couple of weeks to talk to the right person, but i did get it done. they had to update the firmware in the programmers but it is possible.... i did it with an SCT X3 programmer. if you have any questions give me a call 818-521-8109.
C
chuck@EvolutionPerformanc
Guest
Is the fuel system stock, or is it return style? Just wondering because I believe that the controls pack is not compatible with the stock returnless.
