New Best on 100HP Nitrous
Bubbamax
Montreal, Canada
I don't have a lot of nitrous car to compare with in my area so I tought I'll post my new best here for some feed back. I was really please with my 60' time though:leghump:.
1.570 60' and 11.713 @ 117.57 mph 1/4 mile
Temp was around 65 deg and Pressure around 30.06
Bubbamax
Montreal, Canada
Steeda cold Air and TB spacer, SCT,MSD COP, UDP, BMR LCA UCA, Panhard bar, 3.90 with eaton truetrac, steeda Tri-Ax.
Tokico D-spec and eibach spring and swaybar kit.
I use MT ET Street 27/10.5 on a set of RX7 16' wheels at 13 psi.
Stock GT wheels at the front at 47 psi.
Flowmaster and MAC prochamber off-road.
Jack and spare tire removed as well as bottom of back seat.
I think that's it
matt texass
good stuff man..... I havent sprayed mine at the track yet..... still working on getting it complete
psfracer
billy badass
Valencia, CA
What kind of nitrous kit? My best 1/8th mile on n20 was a 7.38 through an auto, but that was on the 150 shot (zex kit, which is 125 on a nx kit). Anyway, that is a great time for only a 100 shot. Too bad you don't have the mph at the 1/8th mile mark, but I bet it was at least 95mph or so.
cekim
Large Member
Earth
Holy super-glue prep'd track! I would not have thought a 1.5s 60 ft was possible with 400BHP....
nice work!
Bubbamax
Montreal, Canada
I use the ZEX kit also...
Did you use the 150 shot on the stock block with the stock fuel system?
Cause when I tried with 125 HP jets I ended up with 3 out 4 plugs destroy on the driver side bank (mind you I only had less than a 1/4 of 93 in the tank left). That was scary, but I'm getting the itch to try again but with race fuel and at leat 1/2 a tank.
Bubbamax
Montreal, Canada
nice work!
Thanks
Well that track is known for the owners to be cheap on glue and prep time (ask Thump_rrr he knows the track), but I guess they did a good job that day.
The week before I did a 1.59 also but missed 3rd gear...
I'm usually at an average 1.62 to 1.64.
M
MattD
Guest
Good run!
I ran the same exact time Friday night with a 1.76 60 ft and at 115mph...heh
