dream07
I had my Ford dealer put 4 new 255/40ZR19 tires on my daily driver 2005 with 2012 premium 19x8.5 wheels. I was all smiles until I got on the highway and from 60mph up the steering wheel was vibrating/shaking (think similar shake as warped rotors while braking and you get the idea). I turned around and drove back, they pulled them, re-balanced them and I left. Same thing, nothing changed. I came back, they did a 4-wheel alignment (only needed minor toe adjustments from my outer tie rod end replacement). I left, same thing, I said screw it.
Recent Maintenance Checklist- new FRPP GT500 front lower control arms, new Ford outer tie rod ends, new GT500 struts, new FRPP GT500 upper strut bearings, new Vogtland springs, and factory wheels that were fine with old 245's.
I have read enough about tire imbalance that I am going crazy. Tire manufacturers say the first choice is to line up the red dot (harmonic spot) with the spot on the wheel that is marked with a dot. Second choice is to line the yellow dot (lightest spot) up with the valve stem.
After reading all of that, I looked at my "dots" and nothing is lined up. Most are 90-degrees or even 180-degrees rotated from the valve stem. The only place that seems like a "mark" is that each wheel has a "4" stamped on it, on the outer lip of the back-side. Is that the "mark" for the red dot??????
The one mechanic said that maybe my tires just aren't round? Should I have them rotate the tires to line up the dots and re-balance? What about having them "road-force" balance them? WTF?
Help!
Help!
