tmcolegr
It's All About the Build
1 gage welding cable for the starter/BEC has been routed to/from the Flaming River (+) battery cable disconnect switch. All terminals were crimped with a battery terminal crimper and heat shrink tubing installed. Boots were installed on the lugs at the (+) battery cable disconnect switch.
After giving it careful consideration, I installed poly wire loom on the cables where they attach to the (+) battery cable disconnect switch. I did this due to their close proximity to the FPDM. I have no idea if this was necessary but figured it would be a good idea.
All interior trim panels have been reinstalled in the trunk. No bulges or tell tale signs of the installation. Sorry for the shitty pictures
One last picture of the Master Battery Disconnect Switch & Fuse Panel. If you look closely you'll notice the only 2 battery cables that are not fused have poly wire loom for additional protection against chaffing
