No start
Timbremmer
Charleston sc
I’ve had issues about a month going on now it would randomly go into limp mode since then I’ve replaced the maf tb all tb connectors and I’m a lost to what’s the cause
Car will start up and then immediately die. I’m not having any vacuum leaks spark plugs are fine injectors are fine fuel pump and filter are brand new I’m not sure what else it could be throwing codes P2106, P061B, P0113. Any help would be appreciated if anyone has had experience with this
StockishS197
Houston
With those codes, it sounds an awful lot like a MAF issue, not TB.
P2106 is the limp mode code. P061B is a PCM code where it’s not able to derive a torque value. P0113 is an intake air temperature sensor (part of the MAF on these cars) high circuit
Is the MAF plugged in? Is it clean? Is the car stock and do you have any way to log with a scan tool or tuner?
Timbremmer
Charleston sc
Maf is replaced and brand new car starts now idles and then dies shortly after attempting to drive still throwing codes P2106 P061B I do have access to scan tool
JC SSP
FL
If the battery is dead it doesn’t matter what brand.
FYI I have AutoZone DL in my GT and in other cars and no issues.
Forty61
Dallas, TX
It will start and idle indefinitely but dies when you open the throttle? Or it will start, idle for a bit and then stall out?
Timbremmer
Charleston sc
maf is installed in the right direction car starts and idles fine second I give it gas it hesitates and then dies out but since this I replaced the old cold air intake with a stock one and am no longer getting any maf or limp mode codes I believe the gremlins worked there way to the fuel side of things now I’m getting extremely low pressure and getting p0191 now for the fuel sensor
StockishS197
Houston
Have you checked all your main grounds? Seems odd that the car would be throwing different codes unless it was something electrical or PCM related.
Also do you have a tuner where you can datalog?
Timbremmer
Charleston sc
I believe I did unless I’m missing any one by the battery one on driver side of firewall and I have a scanner to see live data not sure if I can log it
