the fastest n/a stock LB auto w/stock converter i've seen is around 12.80
stick shift cars of course are much quicker at least until the stock clutch goes away.
Pete i doubt i would change the converter but the gears would probably need to be bumped down to a 3.73 or 3.90
after discussing this with my brother tonight i think I'm going to stick with an N/A combo and just try to build the biggest displacement engine the design will allow. probably based off the new boss5.0 modular block. but who knows. I may show up to Bradenton in the spring with something totally different.
Sounds Good, the reason I said change the converter is b/c 4000 stall is to much on a turbo car , you want to keep it as tight as possible but with enough stall to be able to spool it up.
Does anyone have an Idea whats the fastest time on a Stock Motor, Stock Tranny, Stock Converter Full Weight car with a supercharger or Turbo?
Im talking about a legit street car not one that the seats were removed at the track.
Bradenton is cool Ill be there for sure.
Pete
PM Sent
