nsr stage 2 cams QUESTION
romanGHR
mcallen tx
Does anyone know if i need to replace any bolts or anything
on the swap to the stage 2 nsr comp cams...
TonyN
Ford Junkie
Virginia Beach, VA
I highly recommend you replace the cam phaser bolts. They are TTY.
There is a ton of info if you do a search.
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
What happens if i just reuse mine...
Don't do it. They are one time use for a reason. Once they are stretched, they are worthless if removed. Don't potentially ruin your several thousand-dollar engine because you cheaped out and didn't replace a $15 bolt after spending $700 for camshafts.
romanGHR
mcallen tx
Alright thanks..haven't swaped them yet...does
Anyone have the bolts or instructions easy enough
For me to do the swap??
usafimj
so you bought parts without researching the install or what you'll need for the install
romanGHR
mcallen tx
I did do the research I was just making sure cause some people
Say I don't need the bolts and othersbsay I do...the instructions
I found are very confusing...
usafimj
Search for the Ford service manual. Its somewhere on this site and if that fails google
esworld05
GHR
RGV TX
I told you already wey, you need to buy the bolts :asshat:
