NSR stage II's w/factory stall?
CarbonRight
Going for broke
Galveston, TX
Is it a good idea to run NSR stage II's on an auto with the factory stall and 3.73 gears?
Also, would phaser limiters be a good idea to do with these cams?
radmustangs
Maryland
You dont loose any power down low with thost cams. The car will drive the same as it does now at low rpms. You will be fine with 3.73s
You dont need limiters either.
