Oil in intake manifold
Stang 23
Chatsworth, CA
I'm getting a lot of oil or blow by into my intake manifold. The shop I have it at right now was going to do a compression test and radiator pressure test. There seeing if it possibly blew a head gasket. What do you guys think it could be?
Are you running the stock closed pcv system?
Head gasket would be coolant not oil. Compression test is a good idea.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Got a filter between the intake and driver-side valve cover? That short hose is blowing oil into the intake.
Ssiptang
Downers Grove, IL
I changed to clear hose when I was installing catch can and when engine is running you can literally see oil moving thru
george06
Get a new mechanic.
Stang 23
Chatsworth, CA
Ya I just bought a catch can. so hopefully this will help a lot. It could also be a bad PCV check valve?
