My readings were taken from an Autometer electric oil pressure gauge [ Autometer says the electric is just as accurate as a direct reading pressure gauge ] and Mobil 1 5W 30 oil. Cold idle = 80 +. Hot idle = 22-25. Hot cruise = 60 mph less then 2,000 rpm = 50 psi, 70 mph + 2,200 rpm = 60+ psi. 75-80 mph 2,500 rpm = 70-75 psi. 4,000 rpm + 80-100 psi [ hot ]. You didn't ask, but I think the reason we see such wide spreads in oil pressure compared to older pushrod engines is a result of of relatively thin oils and driving the oil pump directly off the crankshaft instead of off the cam drive. Crank drive = full engine rpm. cam drive = 1/2 engine speed.
