On3 turbo build
GT500KR
Quad Cities, IA
subscribed.
hope you get this figured out man! was going to do this myself as well. going a different route now.
GOOD LUCK
just take your time and be patient. like its been said earlier. deep breathes and and double verify everything... one small thing over looked now can cost thousands...
one other thing is that i did not put on a breather yet where my pcv valve went on passenger side. Totally forgot. can that cause it?
i also did not use a new intake manifold gasket when i took it off for the crossover. I honestly dont remember seeing it. man i need to slow down.
05stroker
Never enough power guy!
Bullard Tx.
Are you saying you think you left them off or just that you reused the old ones?
I have my same ones from 05 on my car and they have been removed several times and reused.
The coupling somewhere. Not completely sure yet. Its really cold ATM and don't feel like messing with it. Plus it's about to snow
Update! I was making boost it seems after all. Somehow I got a boost gauge the reads in bars and not psi. 0.7 bars is somewhere around 10 psi? Anyway I'll get it tuned whenever I get a new throttle body.
I'm pushing boost into the crank case? The valve is open to atmosphere how is there boost going to it?
one eyed willy
Pizzle fo shizzle
Lakeland FL
what do you have connecterd to the driver side valve cover? anything or is it vented to the atmosphere like the passenger side?
crmpman2
crmpman2
suffolk, Va
Yea If you don't put a catch can or breather on both sides you will start smelling oil out the exhuast or even see a little smoke. Just helped zexystang2 with his. Under boost he was getting alot of oil off the driverside and it was smoking just a little bit. Put a Oil catch can on and no more smoke or oil smell.
