one (hopefully) last question about build
graygt07
peoria il.
i picked up my motor from jdm on sunday and went over most of my questions. Everything will be order expect one item. frpp has a kit for the gasket and head bolts part # M-6067-3V46. If anyone has used it let me know, i believe it is the kit i need i just want to be sure before i get to far into the swap. jim thought the kit i needed was alittle over $100 bucks but this kit is only $75. thanks jeff
GB10
8s coming soon?
Burleson, TX
That's the right one. Are you using those tty head bolts or ARP head studs? I'd go with head studs since they are stronger, clamp tighter, and are reusable.
graygt07
peoria il.
jdm said if i didnt plan on taking the heads off in the near future then use the tty bolts. They will work fine
GB10
8s coming soon?
Burleson, TX
As long as you don't go crazy on the boost I'm sure you'll be fine. Even if you did use studs it's still cheaper to buy this head changing kit and not use the bolts rather than buying the head gaskets from ford. Same with the main bolt kit. I bought the FRPP main bolt kit for the cross-mounted bolts and paid $50 shipped as opposed to $12.50 a piece for the 10 cross-mounted bolts from my friend at the Ford dealership. Doesn't make any sense, but oh well. Good luck man.
