MustASH
Happen on track during lapping session, finished on a towing for coming back home...
Engine won't start, or runs for 4-5 seconds then stops. I changed sparkplugs today. Will change fuel filter this weekend.
Seems like no fuel going to the engine since the plugs looks all dry when I look to it.
I suspect fuel filter or pump...
Any other idea ?
Thanks
EDIT :
Potential causes of this misfire code may include:
Damaged or defective Crankshaft Position Sensor (CKP)
CKP sensor wiring or connector fault
Poor fuel quality
Ran out of fuel
Ignition system malfunction
Fuel system malfunction: injector or fuel pump
Mechanical engine problem
Damaged PCM
Any other idea ?
Thanks
EDIT :
Poor fuel quality
Ran out of fuel
Damaged PCM
