psycho bob
FISTER
picked up a 2010 6060 and everything needed for the install. trans, crossmember, driveshaft, pro 5.0 shifter, stock shifter, reverse lockout wiring, and super king cobra clutch.
i've seen alot of issues with these transmissions and clutch, flywheel, slave cylinders. guy i'm getting it from used his stock 2010 GT flywheel w/o any issues. will i be able to use my spec aluminum flywheel with this combo. would it be better to get my spec 3+ resplined for the input shaft and use it.
another question: is there a difference between the stock GT vs stock GT500 drive shaft. maybe the length of the two, but is the GT500 shaft stronger
