Piston and head damage
kwadkins
Piston and head damage. No damage to cylinder walls they look perfect. Also this is the only piston without carbon build up. Any way that the head can be reused??. Thanks!
swflastang05
Back for More
N. Ft. Myers, FL
What the heck got in there? As long as there's not damage that cannot be seen from the pics (i.e. valve seats, etc,) I don't see why you couldn't mill the head and reuse it. I"m sure others with more experience will chime in but that's my $.02.
travelers
Eastern Pa
Have a good shop take a look at the head and pull the valves out and check everything. I would also cc that chamber if everything else check out
weather man
Persistence Is A Bitch
MN
If that is a boosted car, I would replace the head and piston.
kwadkins
It was boosted. I'm tearing it down right now for a rebuild and changing to nitrous. I was going to have the heads cleaned up and reuse them.
05stroker
Never enough power guy!
Bullard Tx.
I had one that looked like that. I just had it milled and gone though, worked fine.
What caused yours?
