plastic on exhaust
etaubenn
Big Red
houston tx
Previous owner told me he ran over some bubble wrap...scraped off what he could and shouldn't be too bad. Unfortunately I didn't look at it closer before signing the dotted line. It's pretty bad. There's not really a good way to get to it so I'm assuming it's going to have to go on a lift to get taken care of.
That being said, anyone know what can be done, if anything, to get melted-now glued- on plastic off pipes?
Luckily the stench isn't soaking into the interior...yet.
Thanks!
etaubenn
Big Red
houston tx
Posted in keeping it clean....but I don't think too many ppl check that out..
Owner told me just as I was buying the car that he ran over some bubble wrap.
I didn't notice it at first, but really looking at it, there's a ton of plastic melted(now glued) to it. Luckily the smell hasn't soaked into the interior yet, but a definite nasty smell after driving for a lil while.
I'm sure I'm going to have to get it on a lift and remove the exhaust...any suggestions??
Thanks!
Houston, TX
I had the same thing happen to me - it was one of those thick mil plastic bags that you buy ice in. It ended up baking on pretty good as I could not get to it right away. I used a palm sander with very fine grit sand paper after scraping as much as I could with a razor blade (used a tool that you can fit a razor blade into like a gasket scraper). What I couldn't reach with the sander I did by hand. It actually came out really nice as compared to the rest of the exhaust system - my exhaust system is stainless steel. You might look at some chemicals to remove it but I was tried of smelling the plastic and resorted to the elbow grease method.
Good luck!
A Flash of Red
A week after I had my Kooks Longtubes and catted x-pipe installed I ran over a large sheet of that heavy plastic wrap that's used in construction. It blew into the road right in front of me and I couldn't avoid it. Stank like hell for awhile. The rep at Kooks said that it would not harm the exhaust and if I really didn't want to wait for it to burn off I could get under there, when the car is cool of course, with some kerosene and it should come off with a little elbow grease. I'm a lazy bastard, so I let it burn off.
Marc s
NASA AIX
Auburn, WA
A plastic 1 gallon milk jug blew out of a truck in front of my car. I ran over it and it wedged in front of my Prochamber. It took a couple of weeks for the smell to go away.
rxpwhistler1
Michigan
If something like goo-gone doesn't lift it up a bit, I may consider trying to use a heat gun to warm it up, then wipe it off with a puddy knife or towel. Then all you would have it a bit of residule, which, should come off with goo-gone or 3M tape remover?
Not an expert, but that's prob what I would try
waketek516
Pedal to the Metal!
Costa Mesa, CA
+whatever # I am
I ran over a heavy duty black garbage bag... smelled for about a week, but eventually burned off.
frank s
at Play
Paradise
You can accelerate the burn-off process by driving a few miles at high revs and low speed (like second gear and 3500+rpm), thereby reducing the cooling effect of passing through high volumes of fresh air. Works good for curing hi-temp exhaust paint, as well.
Awesome answer!
Tech thread of the day for sure!
Threads merged and in correct section. Please don't dupe threads and post appropriately.
etaubenn
Big Red
houston tx
Thanks everyone. Posted in tech cause I wasn't too sure many people would see it...
I think after trying to kill a trans am today...mighta burned some off! He didn't wanna play.
I think I'll just let it burn off. Sounds like it won't last too long. And I don't have a lift. ;-)
