Please help
B37ST1Y
Atlanta
Can anyone tell me what the fresh air line connects to coming from the rear EVAP system? Also, would the line being melted solid prevent my car from starting?
Maddogsvol
Okc
Is that to the fuel tank? Could it mess with the fuel delivery if it’s not equalizing to the atmosphere?
B37ST1Y
Atlanta
Im really trying to figure out why my car isn't starting and the only codes I have that hasn't been addressed is for the evap system but this is all I see that could be an issue.
86GT351
Sunny South Florida
What codes did you have? What parts have been replaced? OEM or aftermarket parts? When ypou say it wont start what is it doing? Crank but no start?
B37ST1Y
Atlanta
It cranks but doesn't start. I had codes for my 4 VVT solenoids so I replaced those, new O2 sensors, new canister purge valve. I still have a P0443 code though.
B37ST1Y
Atlanta
I put new plugs and coil packs in.
I think the fuel is good, the pump starts and when I checked the rail it squirts out.
B37ST1Y
Atlanta
No, I don't have a port nor a tool to check without one. That is could be the issue even if im not getting any codes related to the fuel system?
B37ST1Y
Atlanta
This is what I'm getting, everything is showing green but the car still only cranks work no start.
86GT351
Sunny South Florida
Fuel tank capacity62.45L (16.5 gal)
Fuel Pressure
Key ON Engine OFF (KOEO) 240-530 kPa (35-77 psi)
Key ON Engine Running (KOER) 152-282 kPa (27-41 psi)
B37ST1Y
Atlanta
Thank you @86GT351 and @ryunker, im going to get a pressure tester and doing the test today. Funny thing is that I've had a new pump just never installed it.
