ZmanM3
The Evil One
Wow, sorry about your engine. This is the first I've heard of a MAF failing.
I've sold 3 or 4 of them for the new 5.0's. One was a Procharged car, the others were all stock.Wow, sorry about your engine. This is the first I've heard of a MAF failing.
what would cause them to fail? I would have assumed failing would throw the car into a fail safe mode, obviously didnt happen here.
When the one on my buddys car failed his car simply died and wouldn't restart. We were an hour into a 6 day trip to a Mustang show. I convinced one of my co-workers to pull a sensor from a 5.0 on our lot so we could get on our way.
Pic of the roadside repair:
And it may do that still in certain circumstances. In our case, the car would fire for half a second then die, as if the fuel pump had failed. We spent nearly 4 hours on the side of the road trying to diagnose the car with limited resources. It was only when, on a whim, we unplugged the maf, then tried starting it, and it fired right up.nice lol. i just know with my car i had a intercooler tube come apart which caused the maf reading to be off and in turn put the car into a safe mode, figured if the sensor had gone bad it would have done similar.
just wondering why they are failing and how often they do, And it seems to be a real shitty way for a motor to blow due to a factory maf.
I've been running Kooks high flow cats with my Whipple for almost a year now due to our parish (county) requiring emissions testing. There are only 5 parishes in the state that requires the testing so when I renewed my registration last week, I registered my car to a non emissions testing parish. After doing so, I ordered the off road legs to my exhaust system that remove the cats. As soon as I take them off, I'll post pictures.
Sounds all to familiar. Does procharger have a warranty?
Because the cats can come loose and clog up your exhaust pipe...ask me how I know....and it seems it's either the added fuel for FI or the added air pressure that makes the cats come apart although Lightblades came apart when he was NA.
Lots of threads on here about FI guys that blew out their cats and a couple of them lost engines due to it.
Then how are there 600 plus hp GT500s running factory cats with no problems? It's the aftermarket junk that falls apart.
Is a Parish like a county?
Might be talking out of my ass here, but maybe not...
Car is boosted. Car is tuned. All is well. Uh oh - sensor fails. PCM tries to go into safe mode, but it has a different set of tables - tables that are conservative for a stock car, but don't have enough fueling for a boosted car. Engine goes boom.
Now, I don't know if there is a different set of tables or not, but if there is, and the only ones that are changed with a tune are the normal tables, then that could cause the above.
OEMs fail as well. My buddy just pulled his stockers off his GT500 and they were trash (quoted from his build thread):
"There is the OEM catalyst mid-pipe, and yes, it was shot. The passenger side cat was internally broken up as evidenced by sparkly pixie dust that shifted around when shaken. The damage wasn't apparent enough for photos, but under a flashlight it was pretty obvious to the eye. The driver side unit appeared okay but they are off to the scrapper as a pair."
http://www.fastfordsofcanada.ca/forum/index.php/topic,29.0.html
