gimpy
I ended up popping my motor a few weeks ago and figured I would post up some details on what happened and my build.
Build when popped
Procharger stage 2 10psi (P1SC-1)
BAP
frpp 80# injectors
Boss manifold
stock headers w/catback
What happened
Was out driving the car and goosed the throttle up to about 5k. Right around 4500 the car fell on its face and started blubbering. Took the car in for some datalogging and found a few issues. The maf voltage was at 0volts at any rpm during datalogging and boost pressure was all over the place because of a leaky bypass valve. We replaced the sensor and the valve and did a compression test on all the cylinders. Every cylinder showed 140-145psi except #5 which showed 80psi. Turns out the motor didn't like losing the maf under load!
Aftermath
(4/29/2012) Started to tear the motor down last night and am almost done with the "top side" work. I still have to remove the cats, trans and ac then the motor comes out.
(5/02/2012)
Think im missing something important here...
The pile keeps growing!
Passenger side cat...
driver side...
Im going to try and keep this post updated as I dig deeper.
Build when popped
BAP
frpp 80# injectors
Boss manifold
What happened
Aftermath
(5/02/2012)
driver side...
