Status
Not open for further replies.
TurboPete
Miami, Fl
New Personal Best :
60ft ................. 1.403
330 ................. 4.076
1/8th ................ 6.325
MPH .................. 105.78
1000 .................. 8.269
1/4 .................. 9.909
MPH .................. 137.33
22 psi's , MT Drs 325/50/15s , 3.27 Gear.
Dont have the slip I lost it but here's the video:
http://www.youtube.com/watch?v=ri6LO9v9Bmo
Pete
DraggnRoush
Jimi Hendrix Blues
NYC
I'm whittling it down a bit more each time I race... here's my new best of 11.856 (also my top trap speed) with my back-up run of 11.985.
dysan
Dis-Member
Williamstown, N.J.
New times from first night with e-force
- Cubic inch displacement (CID) of engine: 302
- Type of transmission (by model number): 3650
- Size and Manufacturer of power adder, or N/A: Edelbrock 2.3L E-Force
- Pounds of Boost, of N2O shot (or both if applicable): 10lbs
- Rear Gear ratio: 4.10
- Make and type of tire: M&H 275/50/17 Racemasters
Car # 202 11.640 & 11.691
DraggnRoush
Jimi Hendrix Blues
NYC
Nice job Dysan! That E-Force must be putting a smile on your face... congrats!
dysan
Dis-Member
Williamstown, N.J.
Yeah it's quite nice, but my IAT's are getting too high about 1/2-3/4 the way into the run and it's pulling some serious timing. There's more power in my current set-up if I can get the damn temps down.
I need to get a nice I/C resevoir in there and relocate my battery. That's just more money though which I've got to wait for at this point.
Looks like all you need to do is get a better launch & 60' and you'll be ahead of me.
DraggnRoush
Jimi Hendrix Blues
NYC
I'm working on an intercooler heat exchanger kit for the S197 with my tuner... I'll keep you informed when it's ready. That should solve your heat problem. A larger reservoir will help too, but IMO that won't be enough. Thanks for your comments on my times, I'm sorting out the suspension & that'll really help get my 60' down because the shocks I have now are bad... I'm bouncing down the track!
fordracer666
new personal best
60ft ................. 1.664
330 ................. 4.74
1/8th ................ 7.29
MPH .................. 96.3
1000 .................. 9.50
1/4 .................. 11.35
MPH .................. 122.3
my new personal best . please add me to list
i dont know how to add pics . heres a link to the slip .
http://s904.photobucket.com/albums/ac243/fordracer666/cowl%20hood%20mustang/track%20slip%20pics/?mediafilter=images
Cubic inch displacement stock 4.6
- Type of transmission 5 speed
- Size and Manufacturer of power adder, paxton novi 1200 sl
- Pounds of Boost, 8-9 lbs
- Rear Gear ratio 4.10
- Make and type of tire m/t et streets
i think thats all you need to add me to the list
fordracer666
Run
Thanks man I was pretty excited when I got that timeslip!! I had shift early too rev limiter was kicking in at 6200 rpm for some reason. Waiting for my tuner to respond to me.I had the rev limit set to 6800 and it still wouldn't go past!!
dysan
Dis-Member
Williamstown, N.J.
I got scared shitless on my 4th run at Atco last Friday....apparently someone overheated and spilled antifreeze at the finish line right before me and I went right in it at 120mph. I started fishtailing like crazy and luckily got control back but holy pucker/clinch moment!!!
one eyed willy
Pizzle fo shizzle
Lakeland FL
lol,been there done that....not a fun feeling when the tires break loose at 120mph......
ILW84U
Edmonton, Alberta
New PB & finally in the 10's
There is more in it but for now I'm just glad to see 10's.
- Cubic inch displacement (CID) of engine - 298
- Type of transmission (by model number) - 4R70W
- Size and Manufacturer of power adder, or N/A - Procharger D1SC
- Pounds of Boost, of N2O shot (or both if applicable) - 16
- Rear Gear ratio - 3:55
- Make and type of tire - MT ET streets 12.5x28x15
Status
