Post Your Performance Mods
fhlh
Grabber? Don't Know Her!
Houston
ENGINE
Stock Ford 4.6l 3 valve Long Block
Saleen 2.3L Series VI.5 w/ 3.6 Pulley (making 6psi)
Saleen Extreme Intake System
EXHAUST
Pypes Long Tubes w/ ORX
GT500 Axle Backs
FUEL
GT500 Fuel System
39lbs injectors
DRIVETRAIN
Stock tr3650
Stock Clutch
CHE Torque Limiters
Pro-5.0 / Agent 47 handle
frpp 3.73's / GT500 carbon packs
Ford Racing Girdle
SUSPENSION
Steeda Sport Springs
Koni "Yellow" Sport - Adjustable
J&M Camber Plates
J&M Lower Control Arms
UMI Adjustable Pan-Hard
Sway Bar Relocated
WHEELS & TIRES
AM FR500 18x9 front w/ Nitto NT555 255/45
AM FR500 18x10 rear w. Nitto NT555 285/40
Race Star 15x10 w/ Nitto NT555DR 275/50
To be installed, sitting in garage...
Saleen Boost and Innovate MTX-L a/f guages
UMI Relocation Brackets
Steeda Front and Rear Sway Bars w/ billet end links
AFCO Heat Exchanger
NotQuik
I can't drive
Central Florida
All my mods are in sig aside from the racestars with m/t dr's out back, che torque limiters, eibach prokit with bmr panhard bar. Still rocking the oem paper filter with stock airbox as well.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
I don't care as much about power; I'm all about handling.
Engine, Driveline:
Stock Coyote 302
Suspension
18" Forged TSW Nurburgrings
Nitto NT555s
Steeda chassis bracing
Steeda ultralite springs
Koni adjustable sport shocks
Maximum Motorsports caster/camber plates
Evolution Performance panhard bar and brace
I also have a Fays2 Watts link sitting in my garage waiting to be installed.
Sent from my toilet using Tapatalk.
psycho bob
FISTER
Tulsa, OK
ENGINE
stock short block
jpc ported heads w/ oversized valves
comp 127500 cams w/ phase limiters
arp head studs
edelbrock eforce w/ 3.5" pulley
EXHAUST
stock manifolds & cats
frpp cut in x-pipe
slp loudmouths
Mac LT's & o/r prochamber (need to install)
FUEL
stock pump w/ KB bap
60lb injectors
DRIVETRAIN
TR6060 w/ .50 6th gear
Spec 3+ clutch
Spec aluminum flywheel
DSS driveshaft
True-trac
FRPP 4.10's
MGW shifter
BMR ds safety loop
JPC clutch line upgrade w/ bleeder
SUSPENSION
Eibach Pro Kit springs
BMR:
-stock height K-member
-non adjustable A-arms
-adj. panhard bar
-panhard support
-adj. lca's
-relocation brackets
-adj. uca
Tokico D-Spec shocks/struts
GT500 strut mounts
WHEELS & TIRES
Konig Beyond 18x8.5 w/ 255/45 bfg kdw2
Konig Beyond 18x9.5 w/ 295/35 bfg kdw2
Race Star 15x10 28x11.5 ET Drag
Race Star 15x3.75 26x4 ET Front
