Here is most of it. I am sure I am forgetting something
· Block – 327 cu.in. total displacement, 9.5:1 compression
[FONT="]o [/FONT]Roush Racing 5.0 Iron Block
[FONT="]o [/FONT]Kellogg 3.800” stroke crank
[FONT="]o [/FONT]CP 3.700” bore pistons
[FONT="]o [/FONT]Total Seal piston rings
[FONT="]o [/FONT]Manley 5.85” c-c rods
[FONT="]o [/FONT]Speed Pro rod and main bearings
[FONT="]o [/FONT]FRPP GT500 oil pump
[FONT="]o [/FONT]Triangle Speed Shop billet oil pump gears
[FONT="]o [/FONT]Ford windage tray
[FONT="]o [/FONT]Moroso 7 quart oil pan
[FONT="]o [/FONT]FRPP timing components, steel bodied tensioners
[FONT="]o [/FONT]Pistons and bearings poly coated, all internals machine balanced.
· Heads
[FONT="]o [/FONT]Machine ported Ford 3 valve heads
[FONT="]o [/FONT]Comp 127300 cams
[FONT="]o [/FONT]Comp 12500 valve springs
· Fastners
[FONT="]o [/FONT]ARP cylinder head studs
[FONT="]o [/FONT]ARP main cap studs
[FONT="]o [/FONT]ARP flex plate bolts
[FONT="]o [/FONT]ARP harmonic balancer bolt
· Bolt Ons
[FONT="]o [/FONT]Innovators West SFI approved 10% O/D balancer
[FONT="]o [/FONT]Performance Automatic SFI approved flex plate
[FONT="]o [/FONT]Thump rrr Racing billet belt tensioner
[FONT="]o [/FONT]BGG Racing 8 rib power steering & AC compressor pulleys
· Induction
[FONT="]o [/FONT]Saleen Series VI 2.3 liter supercharger
[FONT="]o [/FONT]JDM ported blower plenum
[FONT="]o [/FONT]2.95” BGG Racing “Gripper” pulley
[FONT="]o [/FONT]Saleen Ultimate air intake system
· Fuel system and delivery
[FONT="]o [/FONT]Ford OEM GT500 fuel pumps, dual FPDM
[FONT="]o [/FONT]-8 an braded fuel lines from pump hat to fuel rail
[FONT="]o [/FONT]Fore Precision fuel rails
[FONT="]o [/FONT]Siemens Deka 60lb injectors
[FONT="]o [/FONT]Ford GT500 throttle body
· Cooling
[FONT="]o [/FONT]Lightning Force Performance double pass 18 fin per inch radiator
[FONT="]o [/FONT]Canton Mustang GT aluminum coolant reservoir
[FONT="]o [/FONT]Meziere WP347S electric water pump
[FONT="]o [/FONT]Gords Performance supercharger intercooler, dual fan
[FONT="]o [/FONT]Moroso GT500 Supercharger aluminum intercooler reservoir
· Driveline
[FONT="]o [/FONT]Level 10 built 5R55 automatic transmission
[FONT="]o [/FONT]Performance Automatic deep sump aluminum transmission pan w/ filler tube
[FONT="]o [/FONT]TCI StreetFighter Ratchet Shifter
[FONT="]o [/FONT]The Driveshaft Shop 3.5” aluminum single piece driveshaft
[FONT="]o [/FONT]Precision Industries triple disk “Stallion” torque converter, 3200rpm stall
[FONT="]o [/FONT]CHE driveshaft loop
· Suspension & Chassis
[FONT="]o [/FONT]BMR Fabrication tubular K-Member w/ ½” lowered motor mounts
[FONT="]o [/FONT]BMR Fabrication tubular lower control arms
[FONT="]o [/FONT]BMR Fabrication lower control arm relocation braces
[FONT="]o [/FONT]Edelbrock aluminum adjustable upper control arm
[FONT="]o [/FONT]BMR Fabrication adjustable panhard rod w/poly bushings
[FONT="]o [/FONT]BMR Fabrication upper panhard rod support
[FONT="]o [/FONT]CHE K-Member brace
[FONT="]o [/FONT]CHE rear axle brace
[FONT="]o [/FONT]CHE radiator support delete
[FONT="]o [/FONT]Belltech rear sway bar
[FONT="]o [/FONT]Ford Racing Cobra Jet front & rear springs
· Exhaust
[FONT="]o [/FONT]Kooks ¾ length tubular headers
[FONT="]o [/FONT]Kooks hi-flow cats
[FONT="]o [/FONT]Pypes “Violator" mufflers
· Miscellaneous
[FONT="]o [/FONT]Autometer SportComp II gauges
§ Electric fuel pressure
§ Electric boost / vaccuum
§ Electric water temperature
[FONT="]o [/FONT]Wide Band Commander Wideband a/f
[FONT="]o [/FONT]Metco Motorsports fuel rail pressure gauge
[FONT="]o [/FONT]Speed of Sound no drill triple dash pod
[FONT="]o [/FONT]Hyperperformance race seats – driver and passenger
[FONT="]o [/FONT]Rear seat delete (don’t remember the brand…they are all the same)
[FONT="]o [/FONT]Jegs Sport Star 15X4 front wheels
[FONT="]o [/FONT]Jegs 5-lug Billet 3/8” wheel spacers
[FONT="]o [/FONT]Jegs Sport Star 15X8 rear wheels
[FONT="]o [/FONT]SLP single solenoid line lock kit
[FONT="]o [/FONT]Canton aluminum power steering reservoir
[FONT="]o [/FONT]Steel braded power steering lines
[FONT="]o [/FONT]UPR catch can – drivers side
[FONT="]o [/FONT]Jegs catch can w/ vent – passengers side
[FONT="]o [/FONT]JDM automatic transmission catch can
· Heads
· Fastners
· Bolt Ons
· Induction
· Cooling
· Driveline
· Exhaust
· Miscellaneous
