Post Your Performance Mods
tmcolegr
It's All About the Build
Central, FL
This thread is intended to be an open invitation/request for all S197 owners to post a complete list of their performance mods and mods which directly support performance mods. It is not intended to include appearance mods which do not enhance performance. So please do not include items like window tint, floor mats, door lock pins, stripes, etc. It is also not intended to be a scrap book of pictures of your vehicle - so if you choose (not mandatory) to include pictures, please limit your post to a max of 2 pictures which support your attached list of performance mods.
Those of you hard core competitive track guys and vendors with shop cars, I'm not expecting you to post your list of mods (unless you choose to), as you have invested countless hours on R&D and thousands of dollars building your vehicles. I can appreciate your reluctance to share those trade secrets and I don't blame you. This thread is intended to be an open healthy exchange of information of which performance mods work together and complement each other.
Please organize your mods by component: engine, transmission, drive line & axle, etc.
Not trying to be a thread killer, as I genuinely would like as many of you that are willing to participate to do so, but if you don't have anything productive to add, do us all a favor and don't post.
Personal note to all: thanks to anyone contributing to this thread, your participation is appreciated.
I will be glad to share my list of mods as an example of what I'm asking for:
Engine
  • ARP Fasteners:
    • 3V Cylinder Head Studs w/12 pt. Nuts
    • 3V Main Cap Studs w/12 pt. Nuts
    • Flex Plate Bolts
    • Harmonic Balancer Bolt
  • ATI Performance Products: Super Damper - Std. 6.5” Diameter/6 Rib
  • Autolite: HT0 Spark Plugs (Gapped @ .030”)
  • C&L Performance: “Racer” Intake Tube w/Bump Hoses & Clamps
  • Canton Racing Products: "Street T" Engine Oil Pan - 8 qts. including filter
  • Comp Cams:
    • High Load Valve Springs
    • Phaser Limiters
    • Steel Retainers
    • XFI VSR Stage 2 Blower Grind Cams
  • Ford: 2V Steel Bodied Timing Chain Tensioners
  • Ford Racing Performance Parts:
    • 60 lb./hr. Injectors
    • Cam/Valve Covers - Powdercoated Black
    • Flex Plate (8 Bolt) - Modified for PI Multi-Disc Torque Converter
    • Throttle Body - Twin 62mm Polished Billet Aluminum
  • Gates: Green Stripe Fleet Runner Micro-V Belt
  • Granatelli Motor Sports: BA-2400 Mass Air Meter
  • JDM Engineering:
    • 298 CID (Actual 301 CID/4.93L) Forged Stroker Balanced Rotating Assembly:
      • Kellogg 3.750” Stroke Forged Crankshaft
      • Manley 9cc Dish 2618 Forged Aluminum Platinum Series Pistons - 3.572" Dia. /.020” Oversize
      • Manley H Beam 4340 Connecting Rods (5.850” Length) w/Full Floating Pins & ARP 2000 Bolts
      • OEM GT 500 (5.4L 4V) Oil Pump - Housing Machined for O-ring
      • Speed Pro Rod & Main Bearings - Std.
      • Total Seal Piston Rings - .020” Oversize
    • SCT 93 Octane Custom Street Tune - Processor Code BKT3 (Strategy FBHR2G4)
    • Cold Air Intake Kit w/K&N Filter
    • Lightning/GMS BA-2400 MAF Sensor Conversion (Pigtail) - Harness
    • Ported Saleen Supercharger Lid
    • Vacuum Upgrade Kit
  • JLT Performance: Oil Separator (Driver’s Side)
  • Saleen:
    • 2.75” (15 PSI) Drive Pulley
    • GT 500 Dual Fuel Pump, FPDM & Harness
    • Series VI 2.3L Twin Screw Supercharger
  • Thump RRR Racing:
    • Billet Aluminum Belt Tensioner w/76mm Billet Aluminum Idler Pulley
    • 76mm (Single Bearing) & 100mm (Double Bearing) Billet Aluminum Idler Pulleys
  • Triangle Speed Shop: 3V Billet Oil Pump Gear
Cooling Systems
  • Engine Cooling System
    • Be Cool: Aluminum Radiator
    • Canton Racing Products: Aluminum Coolant Reservoir
    • Meziere Enterprises:
      • 16 lb. Coolant Reservoir Cap
      • Coolant Recovery Tank
      • Electric H2O Pump w/V10 (5.5”) Idler Pulley
        [*]Relay Kit - Electric H2O Pump
  • Supercharger
    • Afco Racing: GT 500 Dual Pass Heat Exchanger
    • Canton Racing Products: Aluminum Supercharger Tank (Intercooler Reservoir) - Battery Box Mounted
    • JDM Engineering: Intercooler Pump Relay Kit w/Switch
    • Meziere Enterprises: Universal Inline Electric H2O Pump (Intercooler) - 20 GPM
    • Spal Automotive: (2) 5.2” Heat Exchanger Fans w/Relay & Temp. Switch
Transmission - 5R55S
  • JDM Engineering: Aluminum Transmission Overflow/Catch Can
  • Performance Automatic: Deep Sump Aluminum Transmission Pan w/Filler Tube & Dipstick
  • Precision Industries: Torque Converter w/Multi-Disc Lockup Clutch (3,200 Stall)
  • TCI:
    • Billet Input Shaft
    • StreetFighter Ratchet Shifter w/B&M Brushed Aluminum Shift Handle
Driveline/Axle/Brakes
  • ARP Fasteners:
    • 3” Long Wheel Studs - Front & Rear
    • 8.8” Rear Axle Ring Gear Mounting Bolts
  • Axle Exchange: 4” One Piece Aluminum Drive Shaft w/Pinion Flange
  • BMR Fabrication: Dual-Durometer Rear Axle Housing Upper Control Arm Bushing
  • Eaton: Detroit True Trac Differential
  • Ford: GT 500 14” Front Brake Kit
  • Ford Racing Performance Parts: 4.10 Gear Set
  • Hawk Performance: HPS Brake Pads – Rear
  • LPW Racing Products: Extra Low Profile Ultra-Pro Cast Aluminum Differential Cover
  • Metco Motorsports Solutions: Drive Shaft Safety Loop (Front) - Modified for use with 4” Drive Shaft
  • Moser Engineering: 8.8” Rear Axle Main Cap Stud Kit
  • PMP: Line Locks w/Jeg’s Solenoids
  • RPC: Welded Axle Tubes
  • Strange Engineering: Rear Axle Shaft Safety Hubs (C-Clip Eliminators)
Chassis
  • BMR Fabrication:
    • Boxed Sub Frame Connectors (Heavy Duty) - Powdercoated Black Hammertone
    • K-Member with 1/2" Lowered Motor Mounts, Standard Rack Mounts - Powdercoated Red
    • Radiator Support/Swaybar Delete - Powdercoated Red
    • Upper Panhard Rod Support - Powdercoated Black Hammertone
Suspension
  • BMR Fabrication:
    • A-Arms, Light Weight/Non Adjustable - Powdercoated Red
    • Camber Adjusting Bolts
    • Lower Control Arms (Rear), Billet Aluminum w/Poly Bushings - Powdercoated Black
    • Lower Control Arm Relocation Brackets (welded)
    • Panhard Rod (Adjustable) w/Poly Bushings - Powdercoated Black Hammertone
    • Progressive Lowering Springs (1.25” Front/1.50” Rear*) - BMR Red *Axle Housing Modified - 1” Drop
    • Sway Bar Relocation Kit (welded) - Rear
    • Upper Control Arm (Adjustable) w/Poly Bushing - Powdercoated Black Hammertone
    • Upper Control Arm Mount – Powdercoated Black Hammertone
    • Xtreme Anti-Roll Bar - Powdercoated Red
  • CHE Performance Products: Rear Axle Brace - Modified For Use w/BMR Xtreme Anti-Roll Bar
  • Ford Racing Performance Parts: Jounce Bumper Kit
  • QA1 Precision Products: Stocker Star Shocks (Single Adjustable) - Rear
  • Tokico: D-Spec Adjustable Front Struts (Includes Revised 8R3Z-18183-B Upper Strut Mounts)
Exhaust
  • Ford Racing Performance Parts: Mustang GT Sport Mufflers (Borla Stingers)
  • Kooks Custom Headers:
    • Long Tube Headers
    • Off Road X-Pipe
  • Stage 8: Locking Header Bolts
Wheels & Tires
  • M&H Tires: 185/55R17 (26.0"/807 Revs. Per Mile) Drag Radials – Front
  • McGard: Lug Nuts (Open End) w/Offset Washers & End Caps - Front & Rear
  • Mickey Thompson: P325/50R15 (28.0"/750 Revs. Per Mile) ET Street Radial – Rear
  • Race Star Industries:
    • 92 Drag Star Wheels 15" x 10" w/7.5" Backspacing (92-510354P) - Rear
    • 92 Drag Star Wheels 17" x 4.5" w/2.25" Backspacing (92-745342P) - Front
Gauges/Electrical/Supporting Mods
  • AeroForce Technology: Interceptor Scan Gauge w/Analog AFR & Boost/Vacuum Sensors
  • Autometer:
    • Auto gage Full Sweep Analog Oil Pressure Gauge (0-100 PSI)
    • Cobalt Full Sweep Electric Gauges:
      • Fuel Pressure (0-100 PSI)
      • Oil Pressure (0-100 PSI)
      • Transmission Temperature (100-260 deg. F)
      • Vacuum/Boost (30 In Hg.-Vac./30 PSI)
      • Voltmeter (8-18 Volts)
      • Water Temperature (100-260 deg. F)
  • Canton Racing Products: Aluminum Power Steering Reservoir
  • Flaming River: Battery Disconnect Switch w/Remote Lever Kit
  • Innovate Motorsports: Wideband Air/Fuel Ratio Gauge w/Digital Display
  • Metco Motorsports Solutions: Fuel Rail Pressure Gauge Kit
  • MSD: Launch Master 2 Step
  • Odyssey:
    • Billet Aluminum Battery Tray/Mount
    • Dry Cell Battery (Trunk Mounted)
  • Roush: Vent Gauge Pod (AeroForce Technology Interceptor Scan Gauge)
  • Speed of Sound:
    • A-Pillar Triple Gauge Pod (Innovate Motorsports Wideband AFR, Autometer Transmission Temp. & Vacuum/Boost Gauges)
    • Center Dash “No-Drill” Triple Gauge Pod (Autometer Water Temp., Oil Pressure & Fuel Pressure Gauges)
    • Cup Holder Gauge Panel w/4 Illuminated Toggle Switches (Autometer Voltmeter - MSD 2 Step, Line Locks, I/C Pump, Meziere H2O Pump & Radiator Cooling Fan Switches)
Pending Mods
  • RPM 6 Point Roll Bar with Swingouts
white05gt
Illinois
Engine
Paxton 2200
GT500 fuel pumps
FRPP 39 lb injectors
Autolite HTO's
JPC intake
FRPP delete plates
JPC Fuel Rails
IAT sensor relocated to intake
Custom made "paxton" reservoir
K&N breathers
Kooks headers with off road x
Stage 8 locking bolts
Magnaflow cat back
Trans and clutch
MGW shifter
Brakes
Baer Decelarotors
Hawk HPS pads
Steeda braided hoses
Driveline
Dynotech 3.5 driveshaft
Eaton Posi
Moser axles with extended studs
FRPP 4.10's
Suspension
BMR radiator support
BMR k-member
BMR adjustable a-arms
BMR camber bolts
Tokiko adjustable D-specs
BMR billet lower control arms
BMR adjustable upper control arm
BMR upper control arm mount
BMR adjustable panhard bar
BMR Extreme anti roll bar
Cobra jet springs in rear
Steeda HD strut mounts
Miscellaneous
Holeshot wheels
SLP linelock
SOS dual guage pod
Autometer wideband
Autometer boost guage
Shit to be installed
Paxton 8 rib pulleys
IW 10% overdrive pulley
Thumprr tensioner
Catch can setup
Dual durometer bushing for axle housing
LPW rear end cover
I will edit my post if I remeber anything else.
notastockdohc
2005 gt, 5sp stick engine: frpp hotrods, jlt 2 cai, k&n filter, Mac axle backs. Sct xcal2, bbr 93 tune. Drivetrain stock 3:55
Surfstang2020
Myrtle Beach South Carolina
2007 mustang gt auto ; mods are - bbr stage 1 cams custom bbr tune ford racing stinger exhaust jba off road x pipe steeda under drive pulleys and jlt cai soon to be installed jba long tube headers and ford racing 4.10 gears also have nitto 555 rs out back
Sent from your moms phone
Wicked GT
OCD with ADD...
Omaha, NE
tmcolegr, that is quite an impressive build! Here is mine...
Engine:
MagnaCharger w/10# pulley
39lb Injectors
FRPP dual 62mm Throttle Body
FRPP GT500 Dual Fuel Pumps
Steeda Cold Air Intake
SCT Xcalibrator tuner - 93 octane BBR tune
Screamin' Yellow Valve Covers
Trans/Clutch:
Steeda Tri-Ax Short Throw Shifter
Steeda Shift Knob
Suspension:
Steeda Strut Tower Brace
Steeda Competition Rear Swaybar w/Heavy Duty Endlinks
Steeda Front Swaybar
Steeda Billet Lower Control Arms
Steeda Lower Control Arm Relocation Brackets
Steeda Adjustable Upper Control Arm
Steeda Heavy-Duty Strut Mounts
Steeda Pro-Action Struts & Shocks
Steeda Extreme Sport Lowering Springs
Steeda Panhard Bar
Exterior Mods:
Steeda Competition Front Facia
3DCarbon "Eleanor" grill
Steeda Ultralite Hood w/Pins
CDC Windshield Washer Re-Route Kit
Steeda Functional Street Wing
Steeda Ultralite Wheels (Painted Black)
Nitto NT-555's (275/40/18)
Steeda Axle-Back Exhaust
MRT Hood Struts
CPC Radiator Extension Covers
Sequential Tail light Kit
"Powered By Ford" Emblems (Shelby GT stock)
Interior Mods:
SOS A-Pillar 2 Gauge Pod
Autometer Boost Gauge (Cobalt Series)
Autometer Oil Pressure Gauge (Cobalt Series)
SOS Dash Pod
Autometer Water Temp Gauge (Cobalt Series
Autometer Fuel Pressure Gauge (Cobalt Series)
Autometer Air/Fuel Ratio Gauge (Cobalt Series)
All Interior LED's were changed to Cobalt Blue
Silverhorse Remote Trunk Release
Window tint - 20% for all windows
XM Radio
Next Mods:
47lb GT500 Injectors
Upgraded Intercooler
Larger IC Reservoir
AlbertD
Tucson, AZ
I'll play...
Engine (N/A)
-JLT Series 3 110mm CAI
-GT500 TB
-Ford Racing Manifold
-FRPP 39lb Injectors
-Comp Cams SPR Stage 2 (127500s)
-Comp Cams Beehive Springs
-Comp Cams Steel Retainers
-MMR Ported Heads
- 286/203 CFM ports, custom machined factory 34mm intake valvles, custom machined factory 37.5mm exhaust valves, multi axis competition valve job
-Cam Phaser Lockouts
-Meziere Electric Waterpump
-Steeda UD Crank Pulley
-FRPP A/C Delete
-Mishimoto Catch Can
-Evap System Deleted
-Pypes Longtubes w/ off-road x
-Dynomax over-axle piping
-Borla Stingers
-SCT xCal II, Dynotuned by Sanoli Performance in Mission, Tx
Transmission/Clutch
-Stock TR3650
-Stock Shifter
-Fidanza Lightweight Steel Flywheel
-Exedy 400 Clutch
Driveline
-Stock Driveshaft
-Stock Carrier w/ carbon clutches
-FRPP 4.56s
-LPW Girdle
Suspension
-Tokico D-Specs
-Eibach Sportlines (Front)
-BMR Springs (Rear)
-J&M Camber Plates
-Steeda LCA's
-BMR LCA brackets (welded)
-Stock UCA
-BMR UCA mount
-CHE Adj. Panhard Bar
-GT500 Rear Sway Bar
-Sway Bar relocation kit
Chassis
-Stock K-member
-CHE K-member Brace
-UPR Radiator Support
Electrical
-WOTbox
-SLP linelock switch
-Hi-Speed fan switch
Wheels/Tires
-Racestars 15x3.75s/15x10s
-McGard lugs and washers
-Street Setup
165/80/15 Kumhos, 275/60/15 Nitto 555rs
-Drag Setup
26" ET Fronts, 28x10.5x15 ET Drags
tmcolegr
Central, FL
We have a lot of nice rides (much nicer than mine) on this forum: TurboPete, 94TBird, Tiger (and I don't mean Woods!), 05 Stroker, OneEyedWilley, Booshey, Hawgman, AgainstAllOdds1, Silverpoison, just to name a few. Hopefully each will contribute to this thread
tmcolegr
Central, FL
I'll play...
Engine (N/A)
-GT500 TB
-MMR Ported Heads
-Steeda UD Crank Pully
-FRPP A/C Delete
-Borla Stingers
Transmission/Clutch
-Stock TR3650
-Stock Shifter
-Exedy 400 Clutch
Driveline
-Stock Driveshaft
-FRPP 4.56s
-LPW Girdle
Suspension
-Tokico D-Specs
-BMR Springs (Rear)
-J&M Camber Plates
-Steeda LCA's
-Stock UCA
-BMR UCA mount
Chassis
-CHE K-member Brace
-Stock K-member
Electrical
-WOTbox
Wheels/Tires
-Street Setup
-Drag Setup
Your user name is well deserved
mac10chap
The bouncy tits guy...
houston, tx
Engine
Procharger Intercooled @10PSI
Procharger Piggybacked fuel pumps with 40V KB BAP
Autolite HTO's
Steeda delete plates
GT500 T/B
JBA L/T headers with off road H
JBA cat back
Weapons X COP's
Trans and clutch
Hurst Shifter
Exedy 500 Clutch
Driveline
Spydershaft 4" driveshaft
FRPP 3.73's
Suspension
BMR camber bolts
BMR lower control arms w/ relocation Brackets
Eibach Pro Kit
Steeda Motor Mounts
Brakes
Slotted and Drilled Rotors
Hawk HPS Brake Pads
Miscellaneous
REAL FR500 wheels
Typical Gauges with SOS A-pillar gauge pod
tmcolegr
Central, FL
Mac10chap I'm sorry I completely missed your list of mods - your avatar captured my full attention
AbdullaGT500
Little Rock, AR
Engine:
-Ford Racing Whipple High Output Supercharger kit
-VMP mail order tune
-3.4 pulley
-GT500 dual fuel pump setup
-Mac Longtube headers
-Mac Prochamber
-Mac Axle-back
-K&N breathers
-Brisk 2 Degree colder plugs
Drivetrain:
-MGW shifter w/Hurst handle
-FRPP 4.10 gears
-Stock clutch
Suspension:
-Eibach Pro-kit springs
-Eibach Pro-damper shocks/struts
-Steeda Front sway bar
-BMR Billet LCA's
-GT500 Brembo Brakes
Tires:
-Rear: 305/45/18 Nitto 555R Drag Radials
-Front: 275/40/18 Nitto Invo's
Gauges:
-Innovate LC1 wideband
-Autometer Cobalt Series Fuel pressure gauge
-Autometer Cobalt series Boost/Vac Gauge.
Brezick
Yinzer
Engine
Kenne Bell 2.6L blower, 4" pulley
39lb injectors
Kooks Long tube headers
Kooks Off Road X Pipe
FRPP Stingers
GT500 dual fuel pumps
Trans
Stock 5R55S
Level 10 M300 Input shaft
PI Triple disk 3200 stall Torque Converter
Driveline
Dynotech 3.5" Driveshaft
FRPP 4.10 Gears
Detroit Truetrac
LPW Cover
Suspension
QA1 front single adjustable coilovers
QA1 single adjustable rear shocks
Eibach drag springs
UPR adjustable UCA w/ mount and spherical bushings
UPR adjustable LAC's - rod ends
UPR Panhard Rod w/brace
CHE LCA relocation brackets
Brakes
Stock
Next items to get:
BMR K Member
BMR A Arms
BMR Rad support
AFCO radiator & dual pass H/E
Aluminum coolant tanks
Hawk pads
Slotted/Drilled Rotors
Motor:
1L block bored .030" over for 285 cubic inches. Decked for true geometry ct main line.
Mahle Flat Top pistons and rings. 11:1 cr.
Modmax h beam rods with arp 2000 bolts.
Stock crank with sealed power main bearings and speedpro rod bearings.
Stock heads with Comp 26113 springs and 127400 cams. Livernois 20 degree limiters.
Factory tty head and main bolts.
3v oil pump.
Stewart high flow water pump.
Induction:
Forced air provided by Paxton 1200 SL.
Ebay special air to air intercooler.
Drivetrain:
TR-6060 transmission. McLeod RST clutch. McLeod steel flywheel. MGW shifter. Dynotech ds with bmr loop. Tru-track differential. 4.56 frpp gears.
Fuel system:
Returnless with GT500 pumps. 47lb frpp lu injectors.
