Procharger Issue ....
Marc s
NASA AIX
Auburn, WA
The only issue I have with all those breathers is they tend to "drip" oil from time to time. I'd much prefer to run the separator/breather that Mark has on his. My inline catch can does a pretty good job, but I intend on running the same setup as Mark.
That's exactly why I didn't use valve cover breathers. Also, the tank is fairly inexpensive. I also re-used the ends off of the factory lines for a cleaner look.
http://www.summitracing.com/parts/AAF-ALL36109/
05stroker
Never enough power guy!
Bullard Tx.
Thats what I ended up doing .
bullitt boy
NJ
If you use three breathers the only one that will drip is the oil fill even with the baffle.At least thats what I have found to be true on my car.
