Project 67mm build for a redneck
Little update, got my second BAP me so happy now
and got everything installed up front but just didn't look right so i pulled off a couple parts and sent them to be power coated red, down pipe in red cerm coating.
2 strange questions on top of the fuel pump i still have a harness that does not connect to anything is this right????? or what am i doing wrong ???
second i am doing the wiring for the gt500 fuel pumps but i thought i also have to replace a fuse is this correct? if so what fuse ?
JoshK
Modder AKA Fuel
Nebraska
You should have to take two wires out of the plug that used to plug into the fuel hat and then they get installed into a plug to go into the second plug on the new harness. THose wires are for you fuel level. Also, the wire that you run to the fuse panel should come with a fuse holder in it and a 30amp fuse so no other fuses need to be replaced.
http://www.s197forum.com/forum/showthread.php?t=4307&highlight=GT500+fuel+pump+install
Steps 29-31 for the sending wires
thanks you FUEL for the fuse help
still trying to figure out the fuel wiring shit so pretty much i need to pull 2 wires out of the harness to make them work ?
JoshK
Modder AKA Fuel
Nebraska
The original plug that used to go to the fuel hat should have like 4 wires in it. Two of those wires are for the fuel gauge, You need to remove those tow wires from the original plug. The second, smaller plug that can with your new wiring harness should have the male and female ends together. Take them apart and repin the two wires you removed from the original harness into the new one.
I know there are some good pics on this somewhere here. Looking. . . .
thank you
FUEL you are so AMERICAN today
remember what color wires lol i am going to paypal you 2 dollars for this
JoshK
Modder AKA Fuel
Nebraska
The new plug should have a purple with yellow strip and a green with a stripe. THe original plug should have a blueish with yellow strip and a green with a purple stripe i think. The main wire colors are close to the same just put purple with purple and green with green.
You will need to replace the underhood fuel pump fuse with a 30amp as well since you are going to be running baps. Otherwise you will blow the fuse.
JoshK
Modder AKA Fuel
Nebraska
Just ran out and shot some pics. . .
Good point forgot about the BAPs, not running those on my car.
thank you guys so much
last question of the day i promise where is the fuck does this wire go to??????
im lost can't find anything ???
Thats the ac pressure switch connector, goes up front on the drivers side by the radiator.
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
How hard was the crossover install? Take the manifold off and alternator or just manifold? Also were you able to use the gaskets from the 05 cross over in the 07+ crossover ?
