Questions on Line Locks
rojizostang
i love my cams
san antonio, texas
there's another option if you want to piece one together. i ordered a line lock solenoid from biondo racing. it's the same as the moroso. you can purchase just one solenoid and intercept the brake line between the master cylinder and the abs unit. you'll have to purchase a rocker switch and a little bit of wire and a fuse holder, and probably rent a flaring tool from autozone. it takes 1/4" fittings to install the solenoid on the existing brake line. I mounted mine right below the air box. it's a little more labor intensive than buying the pmp kit, however if you're trying to save a little money, then it's worth while....and you'll get a little education trying to figure out how to pass wires thru the firewall....i probably have $75 total in mine, including wire, switch, fuse holder, and solenoid.
if you're mechanically inclined, you can do this easily enough...but the flaring can be a little pain i the butt to get the fittings just right
otherwise...just buy the kit from pmp. costs more, but i'm sure it's a lot easier
ryanralston07
Dalton, GA
PMP with 2 of Jeg's solenoids should be good, but what type of switch and where should I mount it? I'd get a T-Handle for the hurst, but don't care for the finish options in them...
Embalmer
Amateur Expert
Amboy, Illinois
I mounted a leftover switch from the nitrous right in the 12V outlet in the dash:
