Wheels look good. If my car wasn't a daily driver I would invest in a set
Thanks alot!yes at 6 oclock, the way the washer is, the offset shapes it like an egg so the thicker part faces downward allowing it to be centered in the hole on the rim with out the washer sitting slightly on the ridge of the hole, once you look at it closer youll see what i mean and have a better understanding about it. put all 5 lugs on all the way then snug them by hand with a small 3/8 ratchet, then with little weight on the tires torque them the rest of the way, 100 ft lbs. tap is gonna be a 1/2 x 20 tap, clean shavings out good before putting them on, even with the threads tapped has a good tight fit on the stud, so just take your time with each lug, after a few heat and cooldown cycles check torque again to make sure, thats a must on a new set of lugs or studs. anything else youd like to know just ask, anytime dude!
