Re-introducing myself.
jbozz601
Meridian, MS
I'm joe. I'm from Mississippi. I haven't posted in some years. Last time I posted I had a 06 cammed GT. Since then I've owned a 2011 MMR coyote MT82 car that had full bolt ons, full exhaust, clutch, shifter, minor suspension, and bigs and littles. Car made 435/401 and went a personal best 11.39 @121 with a 1.61 60 foot. I traded that car in for a 2014 crew cab f150 2wd. I since picked up a 2005 GT with a little bit of everything. Currently putting some head gaskets, heater core, and some brisk plugs in it and going to retune it. Going to take some weight out and eventually get rid of the t56 and go built 4r70w with a brake. I'm on my phone and don't know how to post pictures and I'm also off shore. Will post picture later once I get home around Wednesday.
-Teksid block
-Full Manley rotating assembly
-8.9:1 compression pistons
-Stage 3 ported heads
-Stage 2 comp cams
-Kenne bell 2.4 supercharger
-16psi supercharger pulley
-Ram twin disk clutch
-Hydraulic throwout bearing
-T-56 viper spec 6 speed trans
-Hurst shifter
-Spec steel flywheel
-Custom steel driveshaft
-4.33 gear
-Full spool
-C-clip eliminators
-Strange 35 spline axles
-Full BMR drag suspension
-2-step
-60lb injectors
-BBK twin 62mm throttle bodies
-Aeromotive stealth 340 fuel pump
-Kenne bell boost-a-pump
-Be cool radiator
ARH longtube headers
-ARH catless h-pipe
-3" magnaflow magna pack cat-back
-Fully adjustable rod ends
-BMR extreme anti-roll bar
-Slotted and drilled Baer decelerators front and rear
-EBC red stuff pads front and rear
-15" race star bigs and littles
photo.php
Kylar
CT, USA
Welcome Joe, sounds like a pretty sick setup!! I think some pics are in order!
