Cali HP Addict
Haha. You shouldn't need to extend the wires at all if you clock the alternator. I take it you got that baby home.
You mean you don't want this to happen to you?
Same here, just took a razor knife to it - didn't occur to me to screw with the alternator case until I read about people doing it since the razor knife fix was so easy...I took a dremel and cut out the red tab on the alternator now my wire points down with no problems and no touching. Plus I switched to the Steeda Carbon fiber inlet tube.
Would someone post up a pic of the positive battery terminal connector that shows a close-up of the alternator cable connected?
Can I ask what importance this is to you?
